Results 1 to 4 of 4
    Nov 2023
    Default opel corsa d security code
    hello i bought an ecu with ignition lock, odometer, keys and fuse box that is located up the feet of the driver, with VIN W0L0SDL6874265651
    I Kept the old UEC with vin W0L0SDL0896001496
    please can i have the security codes for theese two VINs because for the used pzrts i ordered online, it requires the original car documents to get it at OPEL carstor
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by Mgilaj54 View Post
    dealership will myb help you pin by vin but not free,in forum we need reading file from one of cars modules to calculate pin.
    the lesser you use your brain,
    the louder you use your mouth.
    Nov 2023
    Quote Originally Posted by Ninjor s View Post
    yes but at the dealership i need the documents of the car with the vin of the used parts,
    ok how can i read files by obd pleasee? What do i need ?
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Remove dash and read eeprom with programmer,post here the reading
