BMW DME IMMO OFF or HOW TO VIRGINIZE
Results 1 to 12 of 12
    AvechuchoAxel's Avatar
    Downey, CALIFORNIA
    Default BMW DME IMMO OFF or HOW TO VIRGINIZE
    Hello All...
    I'm still looking for solutions on these BMW DME's
    Does anyone know how to do an IMMO OFF or/and virginize the DME to accept be installed on a different vehicle without swapping info from the original DME?
    Any Ideas, Software recommendations, etc.. will be very welcome!!!
    spain
    I think the big problem is with the information of the EWS that is written in the DME
    Downey, CALIFORNIA
    Quote Originally Posted by r12tuning View Post
    Should be great to see how a virgin DMe looks like. How to edit the VIN number that is pre- programmed? Where is the EWS data stored? If I can find this info...I think I will be able to edit the dump and set ALL like factory new. SSS will let me go ahead and st the DME for the new vehicle host.
    Thanks!
    maybe somebody have this sw
    The Legend
    spain
    Quote Originally Posted by rocris View Post
    The Legend
    Yes,but I have read that the cost of BMW INMO Editor interface is very high.
    I think that with bmwscanner should be edited epromm but I don?t know which line is neccessary to change and in where epromm,DME falh eproom or EWS eproom
    Downey, CALIFORNIA
    a little bump in this thread.... still looking for solution.
    Thanks!
    mmm... i have the same problem ! is quite complicated this dump ! if i get any advance i let u know
    I think what you need is ABRITES Commander for BMW and you will be able to do this
    Downey, CALIFORNIA
    Which interface this software use to communicate with the vehicle? Is something that I can build or buy?
    Thanks!!
    Its called AVDI , check it out
    Jakarta, Indonesia
    Quote Originally Posted by tiomilo View Post
    post your dump DME, maybe i can help you.
    regard
    AutoGeek's Avatar
    Jul 2016
    Northern Cape,South Africa
    Hie.I need help with donor DME matching to original CAS and key.Its an automatic.thanks in advance.
