Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Cyprus
    Has anyone figured this out yet?
    Will the TA-SCAN be able to program new smartkeys for this model.
  2. #17
    Cyprus
    Smile
    Not to worry, I found out how to program these keys!
    Took me a while but nevertheless.
    Who dares, wins.
  3. #18
    ...where was Columbus
    Default tell me how
    Quote Originally Posted by Celicagts24 View Post
    Who dares, wins.
    Please tell me how to do it. Thanks for your knowleage
  4. #19
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    Quote Originally Posted by Air View Post
    you may try this >> virginize the immo box,put (FF) on the 93LC66A dump ,then bridge OBD terminal 4 and 13 , insert key ,ignition on for 3 seconds. then off , insert next key , ignition on 3 sec then off .. repeat for all keys, remove the bridge then start the car.
    plz try it then reply your result if possible? cause I didn't try that procedure yet .
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  5. The Following User Says Thank You to pinkfloyd5eg For This Useful Post:
    kyawkyaw (6th August, 2016)
  6. #20
    amir_82013's Avatar
    hi
    Thanks.
  7. #21
    gwee's Avatar
    Dec 2012
    unknown
    No solutions for almost three years??
  8. #22
    Cyprus
    Quote Originally Posted by gwee View Post
    Solution is the main dealer.
  9. #23
    May 2016
    You can work with DENSO tascan ds-2.
    It is also possible to initialize and register the ECU.
    Easier and safer than any tool.
