Toyota Rush (Daihatsu Bego) smartkey programming - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Mar 2010
    Cyprus
    Has anyone figured this out yet?
    Will the TA-SCAN be able to program new smartkeys for this model.
  2. #17
    Mar 2010
    Cyprus
    Smile
    Not to worry, I found out how to program these keys!
    Took me a while but nevertheless.
    Who dares, wins.
  3. #18
    Feb 2010
    ...where was Columbus
    Default tell me how
    Quote Originally Posted by Celicagts24 View Post
    Who dares, wins.
    Please tell me how to do it. Thanks for your knowleage
  4. #19
    pinkfloyd5eg's Avatar
    Mar 2010
    DARK SIDE OF THE MOON
    Quote Originally Posted by Air View Post
    you may try this >> virginize the immo box,put (FF) on the 93LC66A dump ,then bridge OBD terminal 4 and 13 , insert key ,ignition on for 3 seconds. then off , insert next key , ignition on 3 sec then off .. repeat for all keys, remove the bridge then start the car.
    plz try it then reply your result if possible? cause I didn't try that procedure yet .
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  5. The Following User Says Thank You to pinkfloyd5eg For This Useful Post:
    kyawkyaw (6th August, 2016)
  6. #20
    amir_82013's Avatar
    Jun 2010
    hi
    Thanks.
  7. #21
    gwee's Avatar
    Dec 2012
    unknown
    No solutions for almost three years??
  8. #22
    Mar 2010
    Cyprus
    Quote Originally Posted by gwee View Post
    Solution is the main dealer.
  9. #23
    May 2016
    You can work with DENSO tascan ds-2.
    It is also possible to initialize and register the ECU.
    Easier and safer than any tool.
