Results 1 to 15 of 23
    Cyprus
    Default Daihatsu Bego (Toyota Rush) smart key programming
    Hi guys,
    Does anyone know how to program a smartkey for the Daihatsu Bego (Toyota Rush).
    I have the latest software for the Toyota Intelligent Tester II and Daihatsu DS-II but none are able to communicate with either Immobilizer & Smart Entrance systems.
    Any help will be much appreciated
    Last edited by Celicagts24; 30th March, 2010 at 05:00 PM. Reason: posted in wrong category
    If you want help to start car, post your Immo bin file and I will give you the correct key ID to clone to a 4C cloneable chip that will start car.
    Cyprus
    Thanks but the car is fine, just want to program a second smart key but dont know how
    Cyprus
    Well, found out how to program a normal keyfob atleast but this smartkey is giving me a real headache
    I have been trying to figure this out for the last 8 months and still have not done so, I had a job with all keys lost and I was able to read ECU dump and make clone key from dump ,customer bought new smart key with emergency key and I have not been able to program smart key or emergency key. Wish you all the best.
    Smart key? for toyota? then what you need is a tool thats just some few dollars like 50usd. check www.szhtech.com and ask from Faye or buy the more expensive option from abritus72.com from Miro
    toyota smartkey tool ! i dont think will do as they will not get comms try looking for somthing for diahtsu.
    Fallen's Avatar
    From what I understand, Daihatsu use a similar 4D smart key system as Toyota.
    351153-free shipping Daihatsu 4D Key Maker by OBD : eBay Motors (item 300412507586 end time Apr-28-10 22:14:21 PDT)
    These tool will not work, The Daihatsu tool maker can only ADD a second key and that will only work on 4D 68 keys it is NOT for 4C keys which the Daihatsu Bego might use. I did 2007 Toyota Rush which uses 4C key with smart key.
    Cyprus
    Quote Originally Posted by shitad View Post
    I agree, most likely its an entirely different system, when you consider that only the Daihatsu Bego and Passo are equipped with this system.
    I suspect though that since the IT2 & DS-II are not able to communicate with the smart entrance system maybe there is a manual procedure.
    Cyprus
    Anyone that might know to program it?
    Default programming toyota rush or daihatsu bego
    my toyota rush the key fob was lost and also the spare key i need a help to programme this toyota rush 2005 model. so can any one help in this matter. very much thanx if some one get me a solution
  13. #13
    Default toyota rush lost key
    i need to start me toyota rush is sombody can help me with this
    i lost all keys. hope will get a positive answer from you guys soon. thanx
  14. #14
    Dear Sir, i want to plant a 4c transponder inside the dump because client only has smart key and he needs spare key. Car is daihatsu bego, what do i need to read dump from ? ECU or Immobilizer box and where is it ?
    kind Regards
    Locks 85
  15. #15
    La Paz, Bolivia
    toyota passo has the type of transponder epprom 4c and 93LC66, and you can program a new master key with TMpro2, the eeprom is in a module near the IPDM.
