Results 1 to 8 of 8
    Nov 2023
    Default Jeep WJ 2000 PCM eaten by electrolysis - how to clone?
    Hi.
    I'm not able to find the exact box for sale (P56041 869AB) - would it be possible to read out the programming and put it into whatever P56041 PCM?
    Redards / Turbon
    Nov 2023
    Here is a copy of the Fedworld cross reference guide. See if your number is superseded by another and should be able to clone into one of those ecus.
  3. The Following 4 Users Say Thank You to EEpromDestroyer For This Useful Post:
    fuzz1 (1st December, 2023), ricked (2nd December, 2023), Turbon (5th December, 2023), ylie86 (2nd December, 2023)
    Nov 2023
    Thanks a lot EEprobDestroyer! But no luck...
    dimitar's Avatar
    Buy second hand and adapt with pin code ....ive done this with drb3 also launch works too
    You only need the pin from the vehicle...do not open pcm
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  6. #5
    Nov 2023
    Thanks Dimitar.
    But then you had exact matching numbers and just changed the VIN?
    I don't have that, I have P56041 869AB (original, broken) and P56041 868AB (new).
    I need to either program or switch the AB28F200 eeprom.
  7. #6
    Nov 2023
    I would probably need to switch the motorolla cpu too...
  8. #7
    tinchocbr's Avatar
    Nov 2009
    In my house
    with db3 match vin used ecu.
  9. #8
    dimitar's Avatar
    Quote Originally Posted by Turbon View Post
    Dont swap anything just use launch to program new vin
    Even toolbox 2 with good passthru can transfer immo data to new pcm
    50w Soldering Iron
    Chisel
    Sometimes Hammer
