    begi1's Avatar
    Jun 2018
    Bosnia and Herzegovina
    Default Audi A4 B8 2.0 TDI Clone ECU EDC17CP20
    Hello, I have a problem with ECU from this car, so bought used one with same ecu label ( 03L 906 019 AL ).
    Need transfer IMMO data from ORI to DONOR ecu. Who can help me? I can see solutions with EEPROM write to new ecu, but what happened with Flash And what will be with dpf and others?
    THanks in advance!
    If I helped you, dont forget click Thanks and Rep button. Thanks
    Feb 2016
    United Kingdom
    Quote Originally Posted by begi1 View Post
    THanks in advance!
    here is your file with immo transferred
    ask for pass in PM after Thanks + Reputation
  3. The Following User Says Thank You to BmwMerc For This Useful Post:
    begi1 (27th December, 2023)
    kuebk's Avatar
    Feb 2016
    Not much to clone, original ECU has destroyed immo data.
    VAG immo solutions (clone, immo off) MEDC17, SIMOS, BCM2 (eeprom fix), ELV (P160A fix), INVCON.
    begi1's Avatar
    Jun 2018
    Are you sure? The car has no problems with the immo, it starts and runs without problems with the immo, it just has another problem with the ECU.
    kuebk's Avatar
    Feb 2016
    Actually, at first glance the data looks completely lost but after digging deeper it's possible to restore it.
    As you say, there are no immo issues with this ECU, but most (if not all) tools will not be able to properly decode and clone this specific ECU.
    BTW: it might not be an original ECU from this car.
    PM if you are interested in working clone.
    begi1's Avatar
    Jun 2018
    Quote Originally Posted by kuebk View Post
    Thank you, my cousin really needs a car right now, so we decided on immo off as the easiest solution
