addition to the 9346 KOMBI is also changing the mileage in the BSI unit (should be a 95,160).
The BSI is located under the steering to the left.
Post files
Post files
also serves the old mileage accurately, tomorrow will post the files
try this and let me know
how to know type of Bsi
v1-v2-v3 or v4????
but back your original dumps, check if car starts
if it does try using dif version of bsi
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
a question:
you disconnected the battery before unplugging kombi and BSI?
machines such as C2, C3, etc. 206. Always disconnect the battery and better. testing with the original dump is otherwise necessary to "recode" the keys in the BSI with a test that supports it. (otherwise you have to remove im*0
hi
hi someone has virgin dump of bsi?
thanks in advance
regards coelhone
try with im*okiller
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Replace the "*" in the link with "m"
I have never taken im*o. in my country is banned
hi
look door don?t work , car don't start....
what did i do wrong , can someone help?
could be bad dump of 95160 from bsi???
thanks in advance
coelhone
Double check your dump and soldering as sometimes the basics are easily overlooked when in a situation likes this. The bsi units can be very tempremental. Let us know how you get on.
