Results 1 to 2 of 2
Thread: JEEP COMPASS
    Jan 2024
    Default JEEP COMPASS
    Our Jeep Compass do not start. Fault codes zero. CR injectors current and voltage lower than the except values. Other measured parts are ok. With 2nd key do the same, Immo is ok.
    We cleaned the intake manifold/egr systems.
    Have you any idea about this problem? ECU? Thanks.
    Aug 2015
    PL
    What is the engine?
    Does the signal go out to the injectors or just constant voltage?
    By the way check the power supply and ecu ground
