Results 1 to 7 of 7
    Mar 2010
    Default Peugeot 206 BSI, eeprom programing
    From reading on this site it seems that I can replace the BSI by swapping the eeproms from one BSI to the other.
    The BSI is a Siemens S105872400E, BSI T1, 9627137080 03, which eeprom holds the data.
    I have a second hand BSI, but rather than just swapping the eeproms, would like to clone them, we have eeprom programmers at work, but what software do I need to read/write the eeprom's?
    One of the enginners at work is going to repair the orginal unit for me, so I am hoping to just swap them back once the BSI has been repaired.
    Ashraf6119's Avatar
    Nov 2009
    UK
    What's the problem with the car
    Not starting
    Ash
    Mar 2010
    The problems are there are no indicators and the electrice windows only work when the wipers are on, it starts ok.
    I had the relays checked and they are all operating.
    joubliss's Avatar
    Jan 2010
    Far away
    u have to make the BSI Virgin and calculate the code from ur original BSI and Reprogramm it
    dont swap the eeprom it will not work
    racin-snake's Avatar
    Jun 2009
    has this one got coms 200 module ?
    can we have more details inc fault codes ect ?
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    adam28's Avatar
    May 2009
    UK Essex
    It does work if you swap eeprom, as i have done it more than once. Before i had PP2000.
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
    Nov 2009
    Spain
    Hi m8, bsi are two boards, just replace relay board from second bsi to original one.Boards are not welded just pull up with care.
    Regards.
