Results 1 to 4 of 4
    Jan 2024
    Default IMMO Off Audi A3 1.8T AGU 06A 906 018D
    Hello everyone,
    I have a little problem with my car. I tried to read immo eeprom with CH341A and TL886 PLUS II but in both attempts my result is FF FF FF ................... FF from beginning to end. Tl 886 has pinout check so wrong connection isn't possible.
    I am reading chip with clip - not any dedicated adapter, because i don't want to solder the eeprom memory.
    Did anyone of you had similar problem?
    Best Regards
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by marecki88 View Post
    Hello everyone,
    Best Regards
    Remove chip for proper reading
    the lesser you use your brain,
    the louder you use your mouth.
  3. The Following User Says Thank You to Ninjor s For This Useful Post:
    marecki88 (29th January, 2024)
    Jan 2024
    Hi again,
    I desoldered the eeprom chip and i was able to read the data.
    In attachement I'm sharing two bins - original and immo off sollution calculated by me.
    Can anybody with bigger knowlegde than me (amateur ) take a look at those 2 files and tell me did I made it good?
    Hayssam1's Avatar
    Germany
    Hi again,
    your file immo off is okay you are good
    Please Press Thanks Button and Reput if i helped !
  6. The Following User Says Thank You to Hayssam1 For This Useful Post:
