    Dec 2018
    Brisbane, Australia
    Default BMW X5 2006 E53 Cranking no Start
    Hey Everyone,
    Had one of my team make a new key spare key to a 2006 BMW x5 3.0D. After making the key it started once and then went to program the remote in and then the vehicle would just crank and not start.
    The vehicle has an EWS4 and Bosch EDC16C1 DDE/ECU.
    I have tried using our Autel IM608 to do the re sync and adaptation, but it keeps failing and tools saying that the DDE and EWS are not a matching set. Have tried a couple of other Autel tools and Snap on to try the same process but no luck.
    The live data can read the key number and says its good to start.
    I have uploaded the EWS4 Eeprom read via the VVDI Prog and the EDC16C1 Eeprom and Flash's read by the VVDI Multi Prog.
    Could someone see if these files all belong with each other? or see if there is any issues on this end thank you.
    kiszka's Avatar
    Quote Originally Posted by TendedJoker46 View Post
    Hey Everyone,
    https://mega.nz/file/Vqw3VYwC
    save this eeprom to ews
    pass on PM
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    TendedJoker46 (30th January, 2024)
    Sep 2018
    Hey Everyone,
    There is no ISN code saved in ews, therefore it does not work.
    In ecu dme the ISN is 8C84
  5. The Following User Says Thank You to erkor For This Useful Post:
  6. #4
    Dec 2018
    Brisbane, Australia
    Thanks Kiszka and erkor,
    I will try the fix tomorrow and hopefully it all works and let you know.
    achaccha's Avatar
    Nov 2010
    Write please in EWS4 and start engine
    Keep us informed, although EWS4 mostly handles long ISN, but the ecu in this case only has short ISN
  8. The Following User Says Thank You to achaccha For This Useful Post:
    TendedJoker46 (31st January, 2024)
  9. #6
    Dec 2018
    Brisbane, Australia
    Thanks to everyone that sent the files through. Loading one of the new files on and re sync/handshake between the EWS and DDE worked perfectly and then started with all keys.
    Much appreciated with your help and will know what to do if i ever come across this issue again.
