Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 81
  1. #61
    Hollywood
    Where I can buy programmer?
  2. #62
    BG / CZ
    It is ordinary HC08 core chip.
    Solution for the whole problem will be available soon.
    There is another thread in the forum started by me named "Reusing old Peugeot/Citroen remotes".
    It is almost everything about the matter there.
  3. #63
    rob h's Avatar
    May 2011
    Peugeot 206cc 2001
    Bsi siemens, 95160 k-line.
    Remote 2 buttons.
    Transponder, from the remote key, is lost.
    Only org remote still works.!!!!!!
    2 keys in org, dump. Loaded in Tango.
    1 pcf7941 id: Unknown
    2 pcf7936 id: Known
    Then i added a new pcf7936 transponder to this dump, on position 3.
    Car starts, but remote stopped working.
    Why does this key:3 stop the old remote from working?
    The old keys are still in there.
    I tried adding remote manualy, but failed.
    Writing back old dump, restores remote.
    Only programming the new transponder, does not work either.
    I assume that the Pcf7941 is a key with transponder on pcb.
    And the pcf7936, is with the seperate, remaining remote.
  4. #64
    Greece
    206 2001 can't have 7941 remote key
    Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
  5. The Following User Says Thank You to kleidaras For This Useful Post:
    rob h (23rd February, 2018)
  6. #65
    Greece
    Also remote maybe have lost synchronize because you unplug the bsi. But now because you don't have original transponder you can't synchronize back
  7. The Following User Says Thank You to kleidaras For This Useful Post:
  8. #66
    newone's Avatar
    Oct 2016
    no1 is flip,no2 is your remote,i do not think you can save the remote,just program a new remote maybe?
  9. The Following User Says Thank You to newone For This Useful Post:
  10. #67
    rob h's Avatar
    May 2011
    My mistake,
    This car uses pcf7946, and pcf7936.
    However, the transpondery guide does list a 206, with pcf7941.
    I never unplugged the bsi.
    Reading and writing by obd, using Smok.
    So it has to be, the missing transponder. Even if it is still in the eeprom data!
    I am now looking for a new remote key, with matching transponder.
    Some, have seperate transponder, and some on pcb.
    Not sure wich one i need.
  11. #68
    Greece
    206 2001 never have 7946. All this can have only 7936. I have use only original remote on this car. Original remote always have 7936 separate transponder.
  12. #69
    Greece
    Rob h if you want send me vin with pm to tell you what is the original part number from remote your car have
  13. #70
    rob h's Avatar
    May 2011
    Thanks, that would be great, here it is:
    SW vers.: 24.1
    HW Ref.: 9646777380
    Prod Ref.: 9646777380
    Manufacture SIEMENS
    VIN VF32DRFNF42490676
  14. #71
    Greece
    No problem. Tomorrow morning i let you know.. Also i think i have done a 206 with kd and work but i don't remember if is cc or no and what year. I look my notes and tell you.
  15. The Following 2 Users Say Thank You to kleidaras For This Useful Post:
    newone (23rd February, 2018), rob h (23rd February, 2018)
  16. #72
    newone's Avatar
    Oct 2016
    if i remember correct 206 its a total joke,uses 6 diferrent remotes depending year and fog lights,keydiy has some coverage but not all
  17. #73
    Greece
    Quote Originally Posted by rob h View Post
    SW vers.: 24.1
    HW Ref.: 9646777380
    Manufacture SIEMENS
    Genuine Part Number: 6554YR
    on this i have use kd 206cc remote and work
  18. The Following 3 Users Say Thank You to kleidaras For This Useful Post:
    Faraday (25th February, 2018), newone (24th February, 2018), rob h (24th February, 2018)
  19. #74
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    Any advice where to buy blank remote key + transponder id 46 for peugeot 307 2002, good quality, already have a chinese one but different to original key.Many thanks.
    Vag-com, Op-com, Focom, Autocom,Multidiag, Forscan, Lexia....
  20. #75
    rob h's Avatar
    May 2011
    I looked to the keydiy option.
    Not sure which to get.
    There are B series, with seperate transponder.
    And NB, those with transponder on remote print.
    Only B serie listed, is the 1 button remote, with pcf7935 transponder.
    And there is a NB 2 button diplayed with va2 blade, instead of ne73.
    I will try these both.
    If this fails, i will go for the 6554YR remote.
