Results 1 to 5 of 5
    Feb 2024
    Question Skoda Octavia II 1.9 TDI BXE 2009 - General Checksum Failure
    I need help to finish to swap instrument cluster to my skoda. I already solved some problems, bu the last one with airbag, I'm cannot solve, even reading many pages on internet.
    My dashboard is VDO (1z0920843d) with eprom 24c32.
    I copied eprom contents from original to new cluster, configure some modules, correct KM to disappear message ERROR in bottom left, the two keys are working with immo on. Airbag light on with errors.
    In instrument module I got one error :
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 1Z0 920 843 D HW: 1Z0 920 843 D
    Component: KOMBI H21 0110
    Serial number: 00000000000000
    Coding: 110B00
    Shop #: WSC 73430 031 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
    ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
    VCID: 392F2DF919DA6C12085-806C
    1 Fault Found:
    10485825 - Internal Control Module Memory Check Sum Error
    B2000 41 [137] - General Checksum Failure
    [Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    In airbag module :
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD2E1XKX
    Coding: 0000000
    Shop #: WSC 00000 000 00000
    VCID: 3D2739E90172503224D-8068
    8 Faults Found:
    01316 - ABS Control Module
    004 - No Signal/Communication - MIL ON
    01224 - Control Module Does Not Match Vehicle
    000 - - - MIL ON
    01217 - Side Airbag Igniter; Driver Side (N199)
    006 - Short to Plus - MIL ON
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    008 - Implausible Signal - MIL ON
    00589 - Airbag Igniter 1; Passenger Side (N131)
    00003 - Control Module
    014 - Defective - MIL ON
    02511 - Control Module for Seat Occupied Recognition (J706)
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    01042 - Control Module; Not Coded
    000 - -
    Any help is appreciated.
    Cheers from Portugal,
    Rui
    Feb 2024
    Any help? How can I calculate CRC of eprom?
    Esta ai uma trapalhada que nem e bom...
    Aug 2018
    South Africa, Eastern Cape
    1. Send eeprom data from both clusters
    ABS
    Did you have these errors on the old cluster?
    1. ABS control module is not communicating with the ECU, check wiring, check coding.
    2. Your driver side airbag igniter has a short circuit - check wiring, resistance from live data will also help you.... etc
    3. Module is not coded, no basic setting, has not be adapted.
    Feb 2024
    Quote Originally Posted by Siyaonline View Post
    ABS
    1. ABS is working, no error on ABS module
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Coding: 113B201C092300FF881004ED901E00412800
    Shop #: WSC 73430 790 00000
    VCID: 7EF8FCA616AD63EC
    No fault code found.
    The error on ABS module is on AIRBAG module....
    2. Everything is working before change instrument cluster. So I think is fake errors...
    3. Correct, I have the code from a dump of vcds from 2016 where I got the code of AIRBAG, but I cannot program through VCDS or Abrites.
    Now I can upload the actual rom.
