Results 1 to 4 of 4
    DK Veteran m9g's Avatar
    Default How can I extract apps to put on iphone
    I have a touch 2g which is jailbreak'd and want to take the apps of to sell it and then put the apps back onto an iphone 3g
    Is this possible and will the iphone need jailbreak?
    M9G
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Quote Originally Posted by m9g View Post
    M9G
    have a look round for an "ipodbrowser"/iphone
    DK Veteran johnboy1974's Avatar
    glasgow
    just restore the phone via itunes to take it back to factory settings
    DK Veteran ianmac's Avatar
    Oct 2008
    Luton
    M9G
    If you used itunes to sync the apps on your i/touch, then the apps will be stored in the itunes directory, so you can the use the same apps for your iphone, bearing in mind there might be a few compatabillity issues for some apps, between the 2G & 3G.
    Yes, the iphone will also have to be jailbroken for you to be able to use them.
    Hope this helps
    --- Ian ---
