passat 2008 mileage change
Results 1 to 15 of 17
    Jun 2009
    Default passat 2008 mileage change
    hi all, i have a VW passat, year 2008, cluster from VDO (eeprom 24LC32 and micronas CDC3217G), i wanna change mileage for this car but i dont have R250, i have only VAG K CAN COMMANDER 2.5, is there any solution to change this mileage with vag commander 2.5?? thank's a lot
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by aeroyas View Post
    No, sorry you need R250 indeed or VAG PROG for this.
    Hollywood
    XProg-M update
    Jun 2009
    thank's a lot freind's i have try with X-Prog M, but i have no authorisation to read this CPU, no chance for this, thank's anyway
    can you help me?
    I have a Passat 3.2l V6, Bj.2006, with a MED 9.1 ECU. Witch hard and Software do I need to correct the milage ?
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by iceman1 View Post
    can you help me?
    If the car is from before june 2006 you can use vag+k commander, after June 2006 you need more expensive tools like vag prog, enigma, R250 ect...
    Thank you for your answer.
    The Passat is build in 11/2006. So VAG+K COMMANDER doesn`t work.
    My odometer ist a VDO with 24C32 EEprom VAG-Nr.: 3C0 920 870 T.
    My ecu is a Motronic MED9.1 VAG-Nr.: 03H 906 032 AB.
    Do I need two or one Interfaces to change both?
    I thing the R250 is a good choice for me.
    Regards,
    Iceman1
    Default vento (golf 5) r250 no lee en algunos modelos?
    1 pasat 2008
    3 Sales (golf 5 europe) do not work r250
    Why?
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by km-digital View Post
    1 pasat 2008
    Why?
    There are different types of cluster that's why, if you tell us what cluster (visteon/VDO) maybe we can help.
    jackeldestripador's Avatar
    S.A.
    Hello, here i have some Vw Vento with VDO Dash here the numbers
    3HL-00427.07.0794910358
    SW1216 HW 002
    1K0 920 874J
    see attached image. Any ideas how to modify it? When i do it using tachosoft on 24c32 and put in car the back again in original km. help...?
    SORRY!! I see how can i do it.... but i need to update my xprog-m to get BDM adaptor. Thanks anyway
    The same problem
    Is there a solution
    vdo 24c32
    VAG PROG, will get rid of all your troubles
  13. #13
    INDIA
    for micronas 3217 and 3297 vagprog is the best by obd
    no need to remove dash for car
  14. #14
    VOLUMAX's Avatar
    Rousse Bulgaria
    Abrites VAG comander do this job too ! 100% !
  15. #15
    Quote Originally Posted by VOLUMAX View Post
    abrites vag commander is the very EXPENSIVE tool
    also doesnot do the NEC Model (from 2009 onwards)
    but VAG PROG does the cars till 2010 without any problems
    as well as very LESS price than abrites
    also in terms of support SMELECOM'S help desk is far more better than abrites support from ABRITUS
    regards
