which emulator do you have at your disposal?
Hi guys ,
Need a working immo off solution for immo off/emulator on this one .
Renault Kangoo 1.9 (2002) - Bosch EDC15C3 0281011101
Probably all of you will tell me that this one has to use Emulator , i've done several tests with different emulators, several jumper soldered combinations , a few eeprom files with no success . So probably it's an error from my side .
If anyone could help me or guide me some steps , would be appreciated .
Car already came to me with an ecu , with emulator in it . But ecu had water damage .
Even though i could read eeprom+flash files .
Even using those i cannot sync the damn thing .
Thanks in advance
Tested with the 3 that are selected above : emulators.jpg
when using the Jule emulator, you must also edit your ECU EEprom, have you done it?
Yes , I used several jumpers soldered combinations (2+6) and (1+2+6)
Tested some eeprom versions .
I don't know if i can post here my carlabimmo forum link , if anyone is genuinely interested to help me . Cause i've done everything they told me to do , everything their manuals tell ..
Something may be missing , probably on my side .
If you have an original Carlabimmo emulator then you can send your ECU and emulator to Carlab.
They will finish it for you, then you just have to install it.
Just loose your time, you said ecu water damaged, it's not something doing wrong from your side
Get another used ecu and install emulator so as car starts
Man , i'm sorry , i shortened the story because i'm a bit tired of this .
Original Ecu of the car , had some water damage and i could read eeprom+flash.
I've got an used ecu already , written the right flash , written the right eeprom file to work with emulator , and even that , i am still not being able to get this thing working ..
Here is a part of the history , hope i can post this , if not , anyone let me know and i'll edit it out :
https://forum.carlabimmo.com/viewtop...Y5NC4wLjAuMA..
Thank you
