Results 1 to 9 of 9
    Szczecin;Poland
    Default Toyota Corolla 95 immo 89780-12030 problem
    Toyota Corolla, 1995 year of production, immobox 89780-12030 (93LC66 dil). Eeprom dump is broken, car not start. Maybe someone have virgin dump for this immobox ? And another question - how to make synchro between immo and ecu? Car don't have obd2 diagnostic connector...
    vuno01's Avatar
    Europe
    bro its better if you just immo off that car
    and the chip you have to read is in ecu
    and i think its a 93c56 and then just remove immo box
    Quote Originally Posted by bugajewski_pl View Post
    Your dump is no good as you said but you dont need a virgin necessarily, get any good dump for a similar immobox and you can be helped. Also as regards syncing, Look for T1 and E1 in the diag cover and jump the 2sockets for 30 minutes On-ing the ignition, remove jumper after the stipulated time and Off ignition and you are good to go
    Sent from iPhone 4S
    keygargoil's Avatar
    thats well corrupted i have made a virgin file for you but if you have the key data il write the file so you can just write it to the chip
    Nov 2011
    Default THANK YOU FOR POST
    ITS VERY INTERESSENT POST THANK YOU
    Meat-Head's Avatar
    Quote Originally Posted by ayoub123 View Post
    yeah, just thinking thay myself - one of the pub quiz questions on monday, so swatting up now
    Oct 2012
    Quote Originally Posted by sogaro View Post
    Hi, i have a 1996 toyota lancruiser with old 22 pin ODB-1. I not find the T1 terminal, i have Tt or TE1.
    Can you tel me if T1=TE1 or if its an another terminal.
    Thank you.
    Yes it is and if you have both dumps , post as guys may be able to sync for you here
    Sent from iPhone 4S
    Oct 2012
    ok, i try to do this.
    I post the two dump on post i open.
