Results 1 to 3 of 3
    Feb 2024
    Default How to disassemble the Toyota Aygo/Citroen C1 key fob?
    Hello,
    Thank you guys, I finally got the key fob and managed to program it to lock/unlock the doors.
    Now I want to open the case to replace the transponder.
    I unscrewed the little hex, but now I am not sure how to remove the casing because even though I removed the case, it's firmly stuck together and I don't want to break anything.
    What is the proper way to disassemble it so that I can reach the transponder?
    Thanks again
    Jan 2018
    Feb 2024
    Thank you, I have the flip fob so it's not that. However I found how to do it and it worked!
    The following video shows how to do it. It's different key, but very similar: https://www.youtube.com/watch?v=WiACkGW84FA
    (The part where he uses the round nose pliers @ 04:55, I only had regular small pliers but that also worked, I was just a bit more gentle)
  4. The Following 2 Users Say Thank You to mibaup For This Useful Post:
    bmujka (28th March, 2024), nyandacca (29th March, 2024)
