Mercedes for adblue solution ask more and more try this solution i add more if no starts search to buy from someone has davinci deluxe.
send you pass on pm. no need unplug adblue module
Hello Guys,
I have a problem with an Mercedes GLC220 with EDC17CP57.
The Car shows the AdBlue countdown, it can not be erased from dashboard.
First I flashed the car with die File 1. The Countdown still appeared.
Secondly I did the solution with DaVinci. The countdown wasnt there, the Car started. One day later the Car wont start...
It was read and write with Flex on OBD
The Adblue Module is staked out (but too late, after it didnt started already)
I put the Ori, Version 1, and the Davinci solution in rar.
I will be greatfull for any help...
Okay Thank you very much!
I'll try it monday an will Go Back to you monday.
I Hope it Work, the Car is stuck far away...
Do you think it will Work with davinci Deluxe?
I only have the 1.0.28 Version from the Forum..
you are very brave read and write by obd because a friend of mine has a original tool can't remember the name of the tool, to do jobs only by obd because is easier and less time for him and believes if something goes wrong company will pay for a new factory ecu...
hello friend I have already made edc17cp57 complicated to turn off dpf and scr me I made almost 6 FIXWAVE file that my trumpet after 2 DAY Witness finally turns on a friend he made me with davinci deluxe solved
could you upload original and moded files for edc17cp57?
here you go my friend pass in pm disconnect module
Manx thanks for your Help! It workd, the Car Starts and everything is Like it hase to be. Perfect!
