Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Dec 2018
    USA
    Default 2014 Porsche bcm damage
    Costumer called about 2014 Porsche Cayyene all keys lost, when I toke the bcm out I saw someone already tried read it and cut the board, I tried to read it with acdp, vvdi prog, autel, hexprog but nothing.
    Can I get used bcm and program it ?
    Part number 7PP907064HH
    Sep 2021
    NA
    Quote Originally Posted by hananmori12 View Post
    I had many of them repaired after "repair". Usually there is a short in the area where the crystal sits and one of its traces cut and not properly restored. 2 minute job and it is good as new. Not sure what your current case is, but I would start there.
    If board is seriously damaged, I would transfer the MCU or read it on a breakout board and write over to a working board with the same component layout.
    Dec 2018
    USA
    Quote Originally Posted by vov4ik View Post
    Yes he probably tried to read it with vvdi or autel and cut the board, autohex and acdp not required to cut,
    I tried to fix it or read it with all and nothing read it.
    I believe its damage and the data probably too, how I can program a used one?
    Sep 2021
    NA
    Take the crystal off and clean the area with isopropanol, hard to see anything through tons of flux, but it does not look too bad so far.
    Dec 2018
    USA
    Its the ceramic one, the guy before cut it and damaged the point to solder to, i tried to solder there and the pin instead but still nothing
    Sep 2021
    NA
    Unable to see the damage through the flux and with the crystal sitting there, remove the crystal from the board and clean all the area with alcohol so the damage is visible. There would be a short if too much solder gets under the crystal too.
    I usually use thin copper wire to fix traces, bad coils are perfect source for it, do not even need to buy any.
    Edit:
    Make sure you have the MCU Pin 94 short (0 Ohm) to the test point as pictured, if it is not - you will have no clock input and it will not boot. Need to solder thin wire between the two. Also remove excessive solder and clean out the flux.
  7. The Following User Says Thank You to vov4ik For This Useful Post:
    Fallen (29th April, 2024)
  8. #7
    Dec 2018
    USA
    Hi tried again with vvdi prog, hexprog, autel im508 with xp400 and still nothing,
    There is a option to remove the mcu and read it??
    Can I read the rear bcm and get info for this bcm?
    what my options ?!
  9. #8
    rob h's Avatar
    May 2011
    Clean it first. Use some alcohol.
    If needed, paint remover. Let this sit, for a maximum of 10min, then clean it with alcohol.
    Then you should be able to see the tracks better.
  10. #9
    Sep 2021
    NA
    You can sure read the MCU on a breakout board.
    If I had to line you up on this, I would say -
    +clean the board (did I mention it earlier?), flux should not be there, it only takes a spoon of isopropyl alcohol and an old soft toothbrush
    +remove shorts (marked with blue lines) -you can try reading using autel or vvdi after that
    +mount a known good crystal
    +fix the trace using copper wire (marked in red)
    +install in the vehicle and check for comms with module
  11. #10
    Dec 2018
    USA
    I will get alcohol to clean it but the red line you did its not the right one, look on vvdi diagram I uploaded, the line go to a test point above, the other gut destroy that point
  12. #11
    Sep 2021
    NA
    Please. If you want help, then accept it.
    That pad is not important, as long as the via (the hole that makes connection to the other layer) is ok, wire is sufficient. Instead of that point, use mcu leg 94 for clock input for your vvdi/autel. Follow the lineup and you should be fine.
  13. #12
    Dec 2018
    USA
    I appreciate it, I tried to solder a wire to that leg but still didn’t work, I will try to clean it like you mentioned
  14. #13
    Sep 2021
    NA
    You have to remove the short circuits prior to reading (marked as blue lines)
    I would fill the hole (red) with a glue, hope it is not cut through the other layer.
  15. #14
    Feb 2017
    Tunisia
    at least you have to tell memeber if your job is done or not give a feedback
  16. #15
    Jul 2019
    Melbourne, Australia
    I don't think that BCM is worth salvaging, throw that processor on a fresh board.
