just bought one of these and could do with a lot of help setting it up plz
it was helpful thank you
I may need help here.I have Latitude: 52.6596?
Longitude: -1.1210? i dont know hoto in box dm800hdse plz help me
excellent guide Westkill, i was dreading spending a couple of days reading up about this, that made my life very easy. thanks
I know im bringing up a old post but thank's for the tut
also this does not work for me i have to move the dish on my own and find all the sats i need to i cannot get 1w thor for the life of me i can only get 28.2e / 19.2e / 13.2e / on which 19.2 the signal is crap. but 28.2 is 100% why is this?
cheers
Location,size of dish and you may be just off the arc.
Good on some sats and not on others.
If you cant get a lock on a certain sat try and tune into a channel that has a strong transponder that might do the trick and when you're on it you should be able to view other channels from that sat.
http://www.digital-kaos.co.uk/forums...er-guide-7075/
http://www.digital-kaos.co.uk/forums...ze-guide-7076/
Andy.
Thank's andy ive got my dish pointing on the front of the house its probs in the same place and my next door neighbour now i think the high winds have moved my dish a bit but untill these winds stop i cant get up there
i can get a little signal from 13.2e about 37% but no good as the channels do not show.
I guess ill have to get my ladders out when its not so windy
My time is showing 18:31 when the time is 16:49.Time zone is London etc.Can anyone suggest how I get the time correct ? Also after following advice and settings suggested on this site,it still won't move the dish! I can move dish with the buttons on the motorso I know the power is there.
silly question,
i says change lnb to lnb1 to i have to change lnb number for each sat position
Cheers Nacla
many tnx!!! it helps a lot to many nebies like me
Just installed the above system ( hotbird 13, astra 19, astra 28). When using with motorised system , dreambox will boot up when selecting some channels. No problem with fixed dish on Astra ( previous installation).
Used usuals to set it up.
image OpenLi,
Alsat dark motor,
Please help.
Hi, I am new here, just bought a 800hd pvr db but can not get aljazeera card reading on it. Any help is welcome.
using 119w 129w & 110w with a Invacom Quad Polar. I am now wired direct to the invacom, on bird (Verify with a i-link receiver) but can get no Signal or lock..
Where to look???????
(edit) Got a few locks on F3 so muct be my sat xml file?
