Results 1 to 15 of 16
    Lithuania
    Default Opel Astra G 2000 pin code from ECU
    Or does it possible to read pin directly from opened ecu ?
    25c320 .... does im*o pin there ???
    Or how to adapt new used ECU if I cant unlock original ( its broken) and I don't know new ecu pin
    PORTUGAL
    Quote Originally Posted by darius89 View Post
    can you post the details of ECU,,,MAYBE I will help you
    treo's Avatar
    R
    Try to change the capacitor 10uF/35V and start the engine.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    This is dump from reset ECU. Write this in your ECU and then with op-com you can married with immo.
    Lithuania
    can I read/write onboard ????
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    always better to do off board whenever possible
    Lithuania
    problem solved with new capacitors
    Thanks to all
    treo's Avatar
    R
    Thanks to all
    Good job.Well done.
    Aberdeenshire UK
    i need to find the security code for a 2004 astra, i have opcom but read mixed feelings about this, can i read security code with it?
    Belfast, NI
    Quote Originally Posted by mikey4996 View Post
    Engine/ecu type would help!!! Some can some cant! Failing that put the ecu in and read the chassis number the go to stealer for pass ?20iirc.
    Aberdeenshire UK
    sorry...... its a 1.6 16v twinport, 2004 mk4, multec-h ecu.
    I have contacted the dealer but they will not give me the pass cause i don't have the reg number or the V5, told them i have the vin and engine number and year but no joy.
    lupu_sandu's Avatar
    In my immobox...
    Use op-com 090420_DE to find pin code from ECM.
    Search on my post to find this software
  13. #13
    Aug 2010
    perfect software
  14. #14
    Member ingeniero222222's Avatar
    Default Astra 1.7
    Hello, please,
    I can spend this software 090420 I also I have the wrong ECU,
  15. #15
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by ingeniero222222 View Post
    Hello, please,
    try and explain a bit better and write in white
