Results 1 to 15 of 27
    jackeldestripador's Avatar
    S.A.
    Default Opel Corsa i*mo off?
    Hello, some help plz, some ecu to remove i*mo:
    Opel Corsa 1.6
    DELCO
    93355059
    FDST
    27c512 eeprom
    hc11
    Any help wil be apreciated.
    Top Poster + cristi_onofrei's Avatar
    Iasi, Romania
    original file from 27c512?
    S.A.
    Only a half of the file has data. seems to be the same use 27c256...
    kevfield's Avatar
    uk
    is there any MCU inside? moto??
    S.A.
    Yes moto, mask E63M... idon't know so much that mask but
    i think that it's some 68hc11f1
    kevfield's Avatar
    uk
    Ok yes i think your right read mcu save dump as back up ,fill with FF then remove immo box start car
    DK Veteran tomaszcz's Avatar
    ZGP
    Im*o in Motorola F1
    S.A.
    I will try to do some. when results post reply
    thanks guys
    S.A.
    look eprom inside E63M (readed as E87J):
    All FF's
    only on 0x120: 03 FC FF 00 FF FF ....
    right now trying with all FF's
    posting result shortly
    S.A.
    Ok boys all works fine with FF's but i need to change eprom to another who dont have i*mo. See attached
  11. The Following User Says Thank You to jackeldestripador For This Useful Post:
    pablobonome (25th August, 2015)
  12. #11
    kevfield's Avatar
    uk
    Dont understand what u need here explane more
    Thanks kev
  13. #12
    S.A.
    kev, sorry for my bad english and explanation.
    I make it work, puting al FF on hc11 and changing original eprom inside 27c256 to another that has no inmo.
  14. #13
    kevfield's Avatar
    uk
    No! make FF in mcu only,unplug immo box start car
  15. #14
    kevfield is 100% right dont need to touch eprom just fill eeprom with FF and done. tested many times.
    regards
  16. #15
    SAN RAFAEL MZA.
    Default corsa fdst fq
    hola yo tengo un problema parecido, no puedo desinmovilizar un corsa b con ecm 93355059 fdst fq. pudiste dar con la teclas???
