Golf V 1.9 TDI 105 CV - Page 2
Results 16 to 30 of 35
  1. #16
    Spain
    Hello , i've checked all, +12v (30), +12v (15), grounds. It's OK.I think the problem is the ECU. I changed the unit Can Gateway and it does the some.The battery is new.I've phone to technical repair ECU's and he tell me , this ECU is a usual fault to communication CAN BUS.The price...... 450 Euros exchange.The code to ECU is: VW: 03G 906 016 , Bosch: 0 281 011 900
  2. #17
    Spain
    Hello guys.
    Finally i'll find the fault.
    The problem is the ECU. Is typical fault in EDC16 volkswagen brand.
    I've changed the ECU and the car is OK.
  3. #18
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by GabyCR View Post
    You have a problem with ECU. TRy to see if have +12 and good gnd.
    This module golf ECU do have problems for Dry Joints you might have to send the ECU for testing or if can open it and check it for dry joints.
    Have a look at this post from other forum which had same problems.
    Volkswagen, Golf 1.9 diesel 2004. Cut out non start. ****FIXED****
    Hope This Helps
    Ash
  4. #19
    Ashraf6119's Avatar
    UK
    I was bit late to post but, anyway i am glad that you have sorted and its fixed now
    Good Luck
    Ash
  5. #20
    Default coil light
    can anyone help? I have a 1.9 tdi 2006 plate golf, the coil light on the dash has stopped coming on when i try to turn on the ignition to start the car. also my power steering is on before the cars started up. The engine will not start until the coil light comes on. I had an auto elctrician look at it and he couldn't find any fault codes, he thought it could be the ECU. Any thoughts????
  6. #21
    sweden
    Default ?
    yunkyard maybee
  7. #22
    Aug 2010
    you have to change the stop button that is on the brake, if you look the rear light doesn't work correctly
  8. #23
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by Ellervw View Post
    Hi mate
    Brake Light switch will not cause car not to start
    dave,
    Get some one to diagnose the vehicle and see what fault codes you have and post them here, some one will try and help you out.
    But, at the same time I would advise you to start your own post rather than to confuse members with this post as this car is already been FIXED.
    Hope this helps.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  9. #24
    Dec 2010
    Default VW Golf Mk5 2004 1.9d BKC Engine Code
    I looking for some help please!!!!!!
    I've got fault code P0321 and P0322 on my golf. Wont start until codes cleared, then when engine switched off - code errors and again wont start.
    I'm looking for the wiring diagram for the engine so that I can locate that crankshaft position sensor to see if its the problem.
    Any help would be greatly greatly apperciated!!!!
  10. #25
    Ashraf6119's Avatar
    UK
    The Crank Shaft Sensor on this Engine BKC is just near the Oil Filter under there if you look nicely you will see it.
    You got to have small hands to get there
    Hope this helps.
    Ash
    Thanks Ash
  11. #26
    Dec 2010
    Unhappy Golf V 1.9 TDI 105 CV
    Thanks Ash -
    I've got small girlie hands, but my Dad hasn't, LOL. He wanted the wiring digram, so that he could check all the wires, n asked me to have a look online.
    He thinks it might need a new wiring loom, if that make sense!!
    Bit baffled myself, !!!!
  12. #27
    Ashraf6119's Avatar
    UK
    Hi whurlly,
    I don't think he will need the wiring loom, I have done quite a few Crank Sensor on this model So, would go for the new sensor first and see how it get on.
    Ash
    Thanks Ash
  13. #28
    Dec 2010
    Default Golf V 1.9 TDI 105 CV
    Hi Hector,
    Thanks for this. I will give him a phone and see what he has done to the car, as I said I'm not that up on car repairs, LOL, and kind of switch off when he starts getting technical
    I really did think that he wanted the wiring diagram though, and I've called VW but they wont give me it unless I put the car in there to get the work done.
    Do you have the wiring diagram that I could use/give to him??
    ta muchly
    whurlly
  14. #29
    Dec 2010
    Hi -
    Its the pest again!!
    Just checked with him and he has changed the Crankshaft Postion Sensor, but still getting the error codes.
    That's why he wants the wiring diagram, so that he can check that as well.
    Thanks again, sorry for being a bit of a muppet re this, but car has now been off road for over week and its doing my f****n head in!!
    Whurlly
  15. #30
    Ashraf6119's Avatar
    UK
    Hi Whurlly,
    The one marked with red is the Crank Sensor.
    Hope this helps.
    Ash
    Thanks Ash
