Results 1 to 8 of 8
    Jul 2008
    Default image on using flash fxp
    Guy's can I put a new image on using flash fxp...or is there a tut to do this.
    cheers
    Sep 2008
    u can do it with flashwizardpro or dreamup
    check out this thread http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
    Jul 2008
    Quote Originally Posted by scuba View Post
    Hi m8, for some reason null modem cable is not working on dreamup,I've used it on dboxes for years to, Im new the dreambox I can connect through flash fxp so was wanting to do it that way if possible, I think I have to rename image and put in tmp but dont know what the procedure is.
    cheers
    Sep 2008
    as far as i know u can only add fixes with the flas fxp to ur box to get the old image working.Do u know how to use flashwizardpro?
    Jul 2008
    I dont m8, had a look at it and looks a bit complicated .
    cheers
    Sep 2008
    Quote Originally Posted by Skiboy View Post
    cheers
    to me the dreamup is the simpliest way and also the slowest way to do it,make sure the null cable is ok can u check it with some other box?
    Jul 2008
    It works no probs on the dbox m8...just put a cable xml in this image now scanning will see what happens, thanks for your help buddy.
    cheers
    Sep 2008
    ok here is some info u might find useful
    [ame=http://www.youtube.com/watch?v=TfjnD048CvM]YouTube - How to install Image on Dreambox DM600[/ame]
    hope u`ll get it done
