Results 1 to 15 of 23
    Senior Member el_futte's Avatar
    denmark
    Default tuning map passat 1.9PD 130hk
    anobody there have a tuning map map i can try ??
    im using a galetto 1260
    ecu number is 0281010558
    passat 1.9 tdi PD from year 2001
    org map
    I have, probably more then one. Do you want something working or something which will kill your engine? What do you expect? If you want to try something you leave a field for someone to learn on your car!!!
    Get a serious solution!
    denmark
    somthing whit high power (NM) so so much as posible
    You want power or torque? Those are 2 different things. And you still want something for free? I am quite sure someone will post a file from eBay DVD which would not make your engine happy. There are no good tunes for free even for quite easy ECUs like EDC15.
    Oct 2010
    Default Hard modification
    Volkswagen Passat 1.9PD 96kw AVF 2003+
    038906019KD SG 4897 11/02
    39S01966
    0281011205
    FG5JC200
    DK Veteran obnchip's Avatar
    Dec 2010
    Quote Originally Posted by el_futte View Post
    org map
    here you can try
  7. The Following User Says Thank You to obnchip For This Useful Post:
    genadko (27th November, 2018)
    Top Poster luisfm's Avatar
    Feb 2013
    try to do with this map
    Oct 2012
    Quote Originally Posted by luisfm View Post
    your map is a big shit...big smoke from injection....increases 165%...are you crazy?
  10. #9
    Oct 2012
    Quote Originally Posted by obnchip View Post
    here you can try
    NICE WORK OBNCHIP...AND EGR OFF...and 36 HP +....good work...
  11. #10
    Oct 2012
    Quote Originally Posted by djwacik View Post
    maybe your frees remaps are shits my friend...there are sommes tuners here that made good remaps even for free...so take care...regards
    hmmm...a DJ...wacik...who know how to remapp from ebay...
  12. #11
    Feb 2013
    Thank you. This card I picked it up 8 years ago in a car with a friend, and that is a lot of smoke out the car and pushed it.
    I have hung it so they can prove it or investigate
  13. #12
    Oct 2012
    the post is from 13th April, 2010, 05:48 PM....HA HA HA.......PFFFFFFFFF...........
  14. #13
    Feb 2013
    I wish I know how modified power maps, but having the galletto cable when I can copy the maps you cars with chiptuning friends. and I put this is one of them, and wanted to share.
    I have many more.
  15. #14
    Feb 2013
    what is certain, that the map I've gotten yours is going great and will not smoke.
    it is very good map
    thank you
  16. #15
    Oct 2012
    only one thing...you can"t use same map on more cars...every car with his mod file by original file...be carrefully....
