Page 37 of 38 FirstFirst ... 2732333435363738 LastLast
Results 541 to 555 of 560
  1. #541
    Mar 2024
    I have an old MERCEDES audio system Model MF1910 / A 170 820 03 86
    The SN is AL 2910 4 02 16532
    Did someone give some help to find the code for this material
    Thank you for your help
    I hope i will read a respons soon
  2. #542
    shooting's Avatar
    WALES
    Quote Originally Posted by rodel View Post
    Don't Spam! this thread is ONLY for BE3100 radios, not your radio!
    Stick to original thread.........
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  3. #543
    Jul 2013
    STOP SPAM IN THIS FORUM
    ONLY ONE THREAD
    https://www.digital-kaos.co.uk/forum...-MF2910-needed
  4. #544
    Apr 2024
    I need help with radio code
    BE3100X1102304
  5. #545
    Bulgaria
    try code 12344
  6. The Following User Says Thank You to pitgamy For This Useful Post:
    shooting (10th April, 2024)
  7. #546
    Apr 2024
    thanks for the replay
    it's not working
    i entred the code and press RDS but not working
  8. #547
    Apr 2024
    Quote Originally Posted by pitgamy View Post
    try code 12344
    it's not working
  9. #548
    Bulgaria
    Quote Originally Posted by Oussama View Post
    it's not working
    see the serial number again
  10. #549
    Apr 2024
    the sticker is removed over the time
    but there is a carved serial from the side (see the attachments)
  11. #550
    Bulgaria
    this is the coda 12344
    Switch Radio On - Display Shows
    " CODE " With " C " Flashing
    Enter CODE in the order it is read:
    For Example, to Enter Code 12345
    Press Preset 1 then 2 then 3 then 4 then 5
    If the correct code number is now shown
    Press " RDS " To Enter
  12. #551
    Apr 2024
    yes i did indeed the steps when the code 12344 is on screen i press RDS ,it shows "wait" in the screen and show the word "code" with flashing C again
    i travel a lot and need the radio ; im confused i dont know what to do
  13. #552
    Bulgaria
    Please note that code entry is only possible when "CODE" is shown in the display. If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible. If it does not reset after this time, then all of your code entry attempts may have been used up, and the unit will need to be sent to us to be decoded and reset, details of which can be found below.
  14. #553
    Apr 2024
    Yes i think its like you said, i think its not a code problem
    By the way the user manual show the code 41142 but it's not working too
    Thank you for your attention 😊
  15. #554
    Apr 2024
    Its impossible to send the radio to you for fixing because I'm in tunisia, is there a solution for hard reset and re-enter the cods? Like by remove the fuse or the battery, something like that?
  16. #555
    Apr 2024
    Hi again
    I pushed two bottons simultaneously (by luck) the radio redirected me to another hidden menu it shows the radio type 3100IMG20240411184559.jpgIMG20240411184559.jpg, SEA S1018436, SW 26/99 (like in the photos)
    SEA is it mean short for serial??
