Results 1 to 12 of 12
    Default honda city 2004 odometer correction
    http://img695.imageshack.us/img695/1285/image003is.jpg
    hello
    i have tacho universal v2008
    my problem is i am indian & i want my honda city 2004 for mileage correction
    i have tachosoft mileage calculator v19.3
    i have eprom programmer but problem is where to put jumper in ododmeter pcb
    or eprom desoldering & than programmer , than help me how to dissamble speedometer needle
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by rinaprasant View Post
    hello
    Protect dial plate with paper, remove needles with spoons, then remove eprom and read adjust write with programmer.
    thanks for reply i will try & post result
    thanks for good help
    without desolder eprom not programm ?
    HELLO
    WITH YOUR HELP I DONE EPROM READ
    MY HONDA CITY 2004 93C66
    WITH HEX EIDITOR CHANGE MILEAGE BUT NO CHANGE IN ODOMETER
    I UPLOAD DUMP FILE PLEASE HELP ME
    hello
    Honda city 2004 has the L56r within that
    just post the pictures of the Circuit (pcb) plate from the front & the back
    regards
    hello, psg
    i allready upload imeg of pcb & back side imeg is
    Honda City spedometer calibration pics - odometer Honda information
    in india where ?
    i at gujarat
    mo. 9824535417
    but which city of GUJARAT u r based
    i'm having my friend in Ahmedabad who can help u regarding this
    regards
    i at
    RELIABLE MOBILE
    AT.PO. CHIKHLI. DI. NAVSARI
    GIVE YOUR YAHOO ADDRESS OR PH.NO.
    hello
    with the help of forum people i susessfully change my honda city mileage ,,thanks
    but i want to know where is the [ + ] & [ - ] in odometer to check digitl miter & needle properly fix.bcoz to set needle i check odometer in car.
    Wink
    hello
    to fix the needle just refit in the car & turn IGNITION 'ON'
    (as told u earlier on the phone)
    regards
    INDIA
    hello
    no need to remove needle you can do this dash with 6wire
    solder back side of dash
    Quote Originally Posted by qyyum View Post
    hello
    no QYYUM
    he is having the 93c66 & not the c56(L56R) model
    regards
