Page 1 of 5 12345 LastLast
Results 1 to 15 of 64
    NJ
    Default Fault (1.1) - 1.501.9551
    We install version11/2009. We have 2 laptops with software on it and neither one lets you choose cars a choose on main screen. Can anybody help me ?
    Jun 2009
    Good I also am having the same problem.
    DAS works well but does epidemiology with the car.
    Anybody can help me.
    Saudi Arabia
    hello,
    That Fault from the Com port check it did you change it to com2
    Jun 2009
    Good.
    I hereby inform you that already have solved my problem with great help from our contributor Billboard.
    Below is the link to see the solution and get file.
    http://www.digital-kaos.co.uk/forums...3/index32.html
    i hope its work
    Ecuador
    Smile das error (1.1)-1.501.9551
    Quote Originally Posted by darkwolf75 View Post
    hi i have this problem i have a desktop computer all software run well but when i need read the information for a car dont work in star utilities show the next message in caesar test
    ERROR: device '0 (-1) isn't in state available
    Device: Part D
    Toolkit-Resultcode: -1
    i have this configuration in comport
    Bits Per second 19200
    data bits 8
    parity none
    stop bits 1
    Flow Control none
    Comport 2
    i have more comport but i will disable all only open comport 2
    when open a DAS 03/2010
    when try to read information for the car give this message error
    (1.1)-1.501.9551
    i conect the connector 16 pin to a MB c230 Kompresor 2005 in slot in the driver suite i put the car key in second position ingnition, without put on the motor, then i connect the another cable is serial db9 male to a pc the multiplexor when i conect to a car the light is on
    i buy this packet and comes with a harddisk for laptop sata interface, but i make a image from him and i connect to my desktop pc gateway with motherboard 945gct-m3 with pentium e2200 dualcore 2.2 ghz 3.25 gb on ram with windows xp service pack 3
    [PATH]
    DRIVER=.\Driver
    GBF=..\comdat\
    CBF=..\comdat\
    CFF=..\comdat\
    CFG=..\comdat\
    SIM=..\comdat\
    CCF=..\comdat\
    smart = ..\smart\
    [REGISTRY]
    UNIT_KEY = SOFTWARE\DAS\UNIT
    UNIT_DISTANCE = REG_KM
    [SERVER]
    REPORT=0
    PLATFORM=PART_D2
    TRACE_CONFIG = 0
    CAESARMEM = 0
    TOOLKIT =1
    CPULOADREDUCTION=
    PASSTHRU_SELECT_ALLOWED = 0
    CAESAR_DEBUG_LEVEL = 0
    [PKWFehlerArt]
    QUALIFIER=ENVTYPE_
    [EvobusFehlerArt]
    QUALIFIER=ENVTYPE_
    [KW2N_HOURS]
    QUALIFIER=ENV_Betrieb
    [MONITORING]
    MONITORING = ALL
    MODE = DAS_CONTROLLED
    [SHORTTEST]
    ;LOG_SHORTTEST_QUEUES = 1;
    ;WRITE_SHORTTEST_SUMMARY = 1;
    can you help me please
    I have same problem and Im using a usb to rs232 db9 with no IRQ , because this converter dont need it, so my problem is the com port I understand we need a real comportfo DAS, I have in another laptop a PCMCIA rs232 db9 and das 0309 and is working fine, I need to know if there is a configuration to change in das in order to make it work with a usb adapter, any help will be apreciated.
    DK Veteran trigital's Avatar
    Default help
    Without any reason, with latest addons already installed, today my 03-2010 system send me ERROR: (1.1)-1.501.9551 with mux powered and ERROR: (1.1)-1.501.9503 with mux without power
    and into test:
    error
    Device: Part D
    I change the cables,with same results.
    I change the laptop with 2008 DAS and tell me:
    Check serial ... 0 Ok
    CAESAR HW Detection :
    D2Access ... 0 Ok
    D2DownLoad ... 104No download possible
    I open the mux, all voltage seams OK.
    My mux just died?
    Thanks,
    I have same problem: Multiplexer connection failure 9550. Ceasar is test is ok. Have try changed paltform = W->D->D2
    Please anything to do?
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Quote Originally Posted by BimmerGT1 View Post
    DAS will nor work with USB->serial cards (using Prolific drivers).
    Try to find a "real" comport card. The best and most compatible chipset I found is Oxford chipset.
    So get a real COP port PCMCIA / Express card - They are a little more expensive but they will work !!!.
    All the best
    G.
    Quote Originally Posted by trigital View Post
    and into test:
    error
    Device: Part D
    D2Access ... 0 Ok
    My mux just died?
    Thanks,
    I do not think your mux has "died".
    104 fault is Serial Port/Serial Cable / Mux communication fault (to the best of my knowledge!)
    I was faced with this problem (i.e. get this error ob CAESAR test ) however my Mux was and is working fine. It remains a mystery why D2DownLoad gives error 104
    All the Best
    G,
    P.S. Is your mux diagnosing Ok ?? or do you have a problem ??
    What type of serial port are you using ??
    Quote Originally Posted by simppa80 View Post
    Please attach your Caesar test to see.
    Quote Originally Posted by gmatj View Post
    No, I cant connect Mux diagnosticsl. Ceasar Ok? I use normal rS232 serial port with IBM T30.
    Ceasar test:
    Selfdiagnostic
    Device: Part D
    Toolkit-Resultcode: 1
    SDconnect Toolkit - device diagnostic - Part D
    CAESAR STOS+ Rev.:2.12 from Jun 16 2005
    generated protocol file from 23.07.2010 13:53
    SystemCheck :
    D2Access ... 0 Ok
    D2DownLoad ... 0 Ok
    CAESAR Part D2 detected on COM2 with baudrate: 19200
    CAESAR version check :
    D2CheckSNVER ... 0 Ok
    User is Daimler-Benz AG
    User Authentification 1
    Classification 0
    Serial Number 029866
    Authorization Level 4
    Part D
    Hardware Authentification 011205
    Hardware Date 031205
    Special EEPROM check :
    D2 Special EEPROM check:
    Inst. date registered ... 0 Ok
    D2 Special CAN Test :
    Special Test ... 0 Ok
    Classification 0
    Part D
    Slave check :
    D2 Slave check
    D2 Processor ... 0 Ok C165 (mask step CA) is mounted.
    D2 RAM ... 0 Ok
    D2 FLASH ... 0 Ok
    D2 EEPROM ... 0 Ok
    D2 SERCTL1 ... 0 Ok
    D2 UART1/2 ... 0 Ok
    D2 ADC ... 0 Ok
    D2 Display Power Supply :
    D2 Power Battery ... Voltage KL30 = 11.6 V
    D2 Power Ignition ... Voltage KL15 = 11.5 V
    D2 Voltage K-Lines :
    D2 State K-Lines (35) ... Total 3 (+), 32 (-)
  13. #13
    Ceasar test:
    Selfdiagnostic
    Device: Part D
    SystemCheck :
    D2Access ... 0 Ok
    D2DownLoad ... 0 Ok
    Classification 0
    Part D
    Classification 0
    Part D
    Slave check :
    D2 Slave check
    D2 RAM ... 0 Ok
    D2 FLASH ... 0 Ok
    D2 EEPROM ... 0 Ok
    D2 SERCTL1 ... 0 Ok
    D2 UART1/2 ... 0 Ok
    D2 ADC ... 0 Ok
    Everything seems to be Ok and theoretically !!! you should be Ok.
    Have you tried a different set of cables ??
    Also have you installed the fixes by Zolookas ? (copy the three files cal.ini, c32s.dll, lic.sli)
    Did you ever run DAS with the Mux connected before copying above files ?
    Also try another key for DAS.
    and we will always be here to try to help !!!
  14. #14
    Thank you. I have tested mux/cables with other older hdd and it worked wit it. Noe older version is formated and new installed over it..
    I have tryed many fix files. Have also tryed change cal.ini platform W => D, D2 .. I will try other das key. Xentry gives same error. Is bin folder same for das and xentry?
    EDIT:
    ZADAA! It works. Both DAS and Xentry!
    First I changed star developer key. After that it gived error 872. After that I changed cal.ini PLATFORM = D -> D2. Then it started to work. My Serial Port settings are now:
    -Com 2
    -115200 bit/sec (why ceasar detect 19200??)
    -Fifo enabled
    -Resources [x] Automatic settings
    P.S. Now I need to install some Wis or Asra or EPC net. What do you prefer and witch is easy to install? Is Wis possible to full Finnish language?
  15. #15
    EDIT:
    -Com 2
    -Fifo enabled
    My friend I glad you have solved your problem
    (CAESAR tests actual communication)
    Install both WIS and EPC - they are both quite usefull - I am not quite sure about Finnish Language.
    All the best
    G.
