Fault (1.1) - 1.501.9551 - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 64
  1. #16
    Quote Originally Posted by gmatj View Post
    Install both WIS and EPC - they are both quite usefull
    I just started to download WIS-EPC-EWANET_05.2010_DVD. That is ok? Those are so big files that I'm running out of space.. Need now get back up cause get das/xentry work and If I restore back up to other HDD will it work at other laptop? Or need I change something or made new install? Install takes so much time. Have now used many days of my summer holiday for that and not yet Wis/epc installed
  2. #17
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Quote Originally Posted by simppa80 View Post
    Yes that is OK
    WIS /EPC instalatiion is a lot easier. - You need a fresh install
    And Finally do not forget to press the Thanks button on the posts , to those who have helped you !!!
    All the best
    G.
  3. #18
    DK Veteran trigital's Avatar
    I do not think your mux has "died".
    104 fault is Serial Port/Serial Cable / Mux communication fault (to the best of my knowledge!)
    I was faced with this problem (i.e. get this error ob CAESAR test ) however my Mux was and is working fine. It remains a mystery why D2DownLoad gives error 104
    All the Best
    G,
    P.S. Is your mux diagnosing Ok ?? or do you have a problem ??
    What type of serial port are you using ??
    On diagnosis I have 9551 error
    On Caesar:
    SystemCheck :
    Check serial ... 0 Ok
    CAESAR HW Detection :
    D2Access ... 0 Ok
    D2DownLoad ... 104 - No Download possible
    I use the notive com port of my laptop.
    Sistem work perfectly with other mux.
    I notice, that the 104- No Download possible error comes also on a good mux if is not powered on Caesar test.
    Thanks!
  4. #19
    Quote Originally Posted by trigital View Post
    On Caesar:
    SystemCheck :
    D2Access ... 0 Ok
    Thanks!
    Hi again
    I have run a few tests again with 2 Mux- (one was a replacement) Here are the results :
    a) I managed to get a few clean - all pass caesar tests
    b) Most of the tests gave me the 104 error
    c) IN ALL CASES I WAS ABLE TO DIAGNOSE / CODE my w211/facelift/MY2007 (loaded with extras)
    So it remains a mystery why this 104 error comes on - Maybe somebody else whow has come across such a case can shed some light !!
  5. #20
    Also have you installed the fixes by Zolookas ? (copy the three files cal.ini, c32s.dll, lic.sli)
    Did you ever run DAS with the Mux connected before copying above files ?
    Did you change in cal.ini PLATFORM=PART_D2 ?
    Also try another key for DAS.
    and we will always be here to try to help !!!
  6. #21
    hi, I am also having this same error with new compoact 3 kit I bought from china. kit comes with pre-installed das xentry 03/10 on HDD, I have tiried hdd and mux on both ibm t23 and t30, with same error. 501.9551 when trying to connect to car.
    From reading on this extremely helpful forum, I don't think its a mux problem, as caesar test just says 'device isnt in state available' as with previous posts on this thread.
    I have tried editing cal.ini for device = part_d2->d
    com port is set to com2 at 115200 etc., but still same problem.
    i had downloaded zolookas fixes but hav not applied them as yet. I have attached zolookas fixes for anyone who needs it.
    I was wondering if I should try another key first(how do i get another key?) or should i apply zolookas fixes first then if that doesnt work try a different key?
    Please help.
  7. #22
    Quote Originally Posted by dego1500 View Post
    Please help.
    In order to get a key for DAS post you LanId.
    Also if things do not go favourably I would greatly recommend to download DAS2010.01 and make a fresh installation using Zolookas guide letter by letter.
    Mr Zolookas has spent a lot time and effort in order to make installation really easy . And he was nice enough to share with all of DK
    So take advantage of his work !!
  8. #23
    Try also reconnect Car - Mux cable. Sometimes it worked to me.
    After it gives error make reconnection. Mine worket also by 19200 bit/s speed.
  9. #24
    note: DAS will work with USB->serial cards (using Prolific drivers).
    I have tested in two laptop ( asus eepc and ibm t30 ) In the t30 using the internal comport i have this 1.501.9551 error but using the usb>serial everything works ok.
    Cheers,
    red
  10. #25
    Quote Originally Posted by redeaglept View Post
    Cheers,
    red
    I think m8 you got it wrong
    DAS will not work with serial cards using prolific drivers (USB to Serial)
    DAS will work corectly for SURE with Express or PCMCIA RS-232 cards ("real" RS232) using mostly Oxford Chipset and coresponding drivers.
    Cheers
  11. #26
    Member lovelyirshad's Avatar
    cal error 9551 is for hardware so check your cables or com port only
  12. #27
    Quote Originally Posted by lovelyirshad View Post
    lovelyirshad
    You are posting all over the place .......
  13. #28
    sorry, been busy with stuff why hadn't checked the thread.
    Ok, I tried zolookas fixes, and tried developer key, but still same error. Also did some other bits but didn't change a thing in caesar test.
    I am convinced its a cable or comport problem, but since it was the same in my T23 which had a verified com port, I am leaning towards a faulty cable , namely the rs232 to rs485 converter cable.
    I contacted the seller (china) and they also said it is most likely this cable. They will send me a replacement cable free, this should arrive sometime after the bank holiday.
    i will let you guys know if this solves it!
    cheers.
  14. #29
    I'm back and happy to report that it was indeed the cable (rs232 to rs485) which was faulty.
    Now my das is working fine !!!!
    Thanks to everyone for their help, really appreciated.
    Now , I would like to use xentry, but before I do so, do I need any special keys , or only if i want to run xentry dev mode.
    Also, do I need to apply the timeout fix or should i run it and see first?
    Thanks guys.
  15. #30
    Oct 2010
    Thailand
    das fault 1.1 how to fixed it.
    thank you
