I come back with same problem,
I change all the max's, UART, regulators and still the same '104 - can not download"
On diagnosis I have 9551 error
On Caesar:
SystemCheck :
Check serial ... 0 Ok
CAESAR HW Detection :
D2Access ... 0 Ok
D2DownLoad ... 104 - No Download possible
I use the notive com port of my laptop.
Sistem work perfectly with other mux.
Thanks,
Could you please specify some of that cards please?
Im having trouble connection to the car this thing also and its most likely the USB to Serial COM cable... its a prolific ou something like it also have a ATEN or ATENA cable that dosent work.
Could you tell me where to buy that PCMCIA Cards ?
You could send me some in private message i have no idea the name to look for this in Portugal... and have no clue where to find them in Portugal stores...
with that card got the same error ... everytime ... used 3 diferent and none worked..
could it be the cables from the multiplex to the computer that are damanged?
I'm having the same problem of error D2DOWNLOAD 104 no download possible, in CAESAR test.
I checked the cables and they are good, not sure if the china mux as fried or not, but I get the green ligth and in DAS it shows voltage, but after selecting the car it gave error 30 31.
I'm using DAS 3/2009, any ideia how to solve it guys?
PS: I will try with a PCMCIA card I have here with oxford chipset to see if is the onboard RS232 problem.
I used the onboard RS232 port of my toshiba laptop and worked for 1 year.
I also saw some mentioning on this forum that clone interfaces don't support the 24v of trucks and is what for I'm using in the last year with no problems!
PS: I will try the RS232 PCMCIA oxford, but any sugestion beside that?
I have (1.1) 1.501 ONLY!
I checked 2 different mux c3. Same problem.
DAS 07.2010 on virtual machine (cesar not work)
Have any ideas?
Thanks advance!
