We install version11/2009. We have 2 laptops with software on it and neither one lets you choose cars a choose on main screen. Can anybody help me ?
Good I also am having the same problem.
DAS works well but does epidemiology with the car.
Anybody can help me.
hello,
That Fault from the Com port check it did you change it to com2
Good.
I hereby inform you that already have solved my problem with great help from our contributor Billboard.
Below is the link to see the solution and get file.
http://www.digital-kaos.co.uk/forums...3/index32.html
i hope its work
cal error 9551 is for hardware so check your cables or com port only
sorry, been busy with stuff why hadn't checked the thread.
Ok, I tried zolookas fixes, and tried developer key, but still same error. Also did some other bits but didn't change a thing in caesar test.
I am convinced its a cable or comport problem, but since it was the same in my T23 which had a verified com port, I am leaning towards a faulty cable , namely the rs232 to rs485 converter cable.
I contacted the seller (china) and they also said it is most likely this cable. They will send me a replacement cable free, this should arrive sometime after the bank holiday.
i will let you guys know if this solves it!
cheers.
I'm back and happy to report that it was indeed the cable (rs232 to rs485) which was faulty.
Now my das is working fine !!!!
Thanks to everyone for their help, really appreciated.
Now , I would like to use xentry, but before I do so, do I need any special keys , or only if i want to run xentry dev mode.
Also, do I need to apply the timeout fix or should i run it and see first?
Thanks guys.
das fault 1.1 how to fixed it.
thank you
I come back with same problem,
I change all the max's, UART, regulators and still the same '104 - can not download"
On diagnosis I have 9551 error
On Caesar:
SystemCheck :
Check serial ... 0 Ok
CAESAR HW Detection :
D2Access ... 0 Ok
D2DownLoad ... 104 - No Download possible
I use the notive com port of my laptop.
Sistem work perfectly with other mux.
Thanks,
with that card got the same error ... everytime ... used 3 diferent and none worked..
could it be the cables from the multiplex to the computer that are damanged?
I'm having the same problem of error D2DOWNLOAD 104 no download possible, in CAESAR test.
I checked the cables and they are good, not sure if the china mux as fried or not, but I get the green ligth and in DAS it shows voltage, but after selecting the car it gave error 30 31.
I'm using DAS 3/2009, any ideia how to solve it guys?
PS: I will try with a PCMCIA card I have here with oxford chipset to see if is the onboard RS232 problem.
