Results 1 to 15 of 28
    Default Fiat Panda 169 radio BOSCH
    Can you help me for disable code error (cancheck) and find radio-code on this radio, made by BOSCH THANKS in advance
    alexics's Avatar
    Kidderminster
    Quote Originally Posted by giuseppe View Post
    Your code is 5534. I will get back to you shortly on can check.
    alexics's Avatar
    Kidderminster
    Hopefully this will turn your can check off.
    Alexics, can you re- ipload the file? It's no valid archive .ZIP -- THANKS --
    DK Veteran deffc0n's Avatar
    UK/POLAND
    Code by serial
    alexics's Avatar
    Kidderminster
    Quote Originally Posted by deffc0n View Post
    Code by serial
    I didn't get the code via the serial number I read it out of the dump.
    alexics's Avatar
    Kidderminster
    Can you try the link again I have just downloaded it from here and it opens fine for me.
    got the same problem with a Fiat Punto Evo Radio from Delphi..
    Will try your method...
    FiatP
    UK/POLAND
    Give me serial this radio
    alexics's Avatar
    Kidderminster
    I have no idea what the serial number is I didn't look for it. If you don't believe me then send me a dump and tell me what code number you want in it. :-)
    Alexics,
    95640 is 8,00 Kb
    your file is 1,63 Kb
    UK/POLAND
    Maybe radio is damage ?
  13. #13
    murat332's Avatar
    Türkiye
    better option, if the binary file record
    always binary
  14. #14
    alexics's Avatar
    Kidderminster
    Alexics,
    95640 is 8,00 Kb
    When I downloaded you original zip file that was the size of the file you sent. I simply edited it and sent it back. I would check your original file and post it again. I will re-edit it for you.
  15. #15
    alexics's Avatar
    Kidderminster
    Quote Originally Posted by FiatP View Post
    FiatP
    If it is a cancheck problem it won't work. Different model. It is possibly a grundig set. Do you have all the details off the radio?
