Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 83
  1. #16
    Quote Originally Posted by Curious123 View Post
    Has there been an image that has worked on the box and if so which was that? What was the last image you flashed on the box? Are you using a null modem cable with an USb connector at one end? What version of Windows are you using and is your firewall tured off? Have you tried the latest DreamUP and the oldest DreamUP?
    every image worked but stucks to language selection.
    i have tried to windows xp,7 with usb adapter and without.
    last image worked correctly was pli.
  2. #17
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Quote Originally Posted by vasilism13 View Post
    People who have used the null modem cables with an USB connector at one end have had issues with the drivers. I would definitely use one without a USB connector. The latest Open Pli images do not work on clones so best to stick with Pli Jade 3 image if you have a clone.
  3. #18
    i have an origianl box.
    you think is damaged?
  4. #19
    Quote Originally Posted by bubbles69 View Post
    This patched version of dreamup witch has fix for dm500 lock bits error, and dm800 no ca...
    DON'T FORGET THE THANKS BUTTON
    does the OLD version really help ? where to get it ???
    THANKS
  5. #20
    does the old version of DreamUp help? where to get it ?
    THANKS
  6. #21
    nothing for me.
  7. #22
    What type of null modem cable are you using i.e does it have a USB connector? Try d/l and installing the original from DMM and then your preferred image.
    Downloads | dream-multimedia-tv.de
    I have the same problem
  8. #23
    ERROR resetting lock-bits!! can eny body halp me
  9. #24
    bubbles69's Avatar
    Somehwere in the South East
    use patched version of dreamup this is what i used to fix lock bits error
  10. #25
    Aug 2010
    hola a todos voy a provar esta version de dreamup a ver que pasa mi dreambox ya me tiene loco
  11. #26
    Sep 2010
    Default me too
    i can't erase flash for DM500S
  12. #27
    Can't upload flash image, gemini 4.3...
    Erased old one with NULL MODEM cable, but got errors while uploading... any sugesstions?
  13. #28
    Dec 2010
    Default Need Erase.bin DM500
    Plz i need a erase.bin of DM500
  14. #29
    Dec 2010
    Quote Originally Posted by ftouhms View Post
    here you are dear forume !! i hope it will help you solve your problem.
  15. #30
    Jan 2011
    Hi.
    I had the same error but used Dreamup V1.3.2.1 and it worked. My only problem is that the box freezes up on loading with all the images I tried. The remote does not respond nor does the power button on the front of the box. I am using DM528s. Can anyone help with the freezing problem.
