Thank you for the image file, it was needed very much
I HAVE THE SAME PROBLEMS
hi to all
I tried to flash plijade3 with flash wizard but it stuck to 84% and now the dm has a black scrren nothing at all can you help me please .. i dont know how to flash again because the dm is not starting and i cant connect to it
regards
shpendi
try with dreamup mate. it may rescue it..of course you should have used dreamup first..still 20-20 hindsight eh?
am going to down load this and try as i have the same problem unable to flash. i borrowed my box to a ammatuer and he flashed it but it failed. Now i just get the flash message on boot up and then sticks on blue GP screen !!!!! AAAAAAAagggghhhhhh
Dreamup has many versions the latest version is designed for the dm 800 .for the 500 please use older version. 3.1.4 ,that will fix your problems
my dm500 can't boot
hi
I can't make a flash update it wont leave acknowledgement
Pls help
My dreambox hangs on boot will the erase.img help ?
If you all started your own threads instead of asking different questions in this one you might have more luck.
Also introducing yourself in the relevant section might help and having a read of the rules.
Forum Rules
Introduce Yourself
Welcome to the forum
Andy
same problem, i used darkness 2 flash then got same message error
Same problem here not connecting at all via dreamup v 3.1.3
