Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    Quote Originally Posted by sogaro View Post
    Nee help please for this Murano 2004 , here is attached dump
    need 95,876miles
    Murano Kansei dash:
  2. #17
    Feb 2010
    @Bram, i noticed the line 000000 with FF FF 20 8A does not show anything but 0.00 and when it does it changes per ignition on and off. WHen its swapped as FF FF 8A 20, it give a high mileage but works
    VICTORY AT LAST>...................Bram380' s file worked perfectly. Thanks so much Y'all
    Sent from iPhone 4S
  3. #18
    DK Veteran lashkar97's Avatar
    Jan 2012
    Indonesia
    friend i send 2 files one is 95xxx and other is 495xxxxx
    check that files its 100% work its by TIA
  4. #19
    Feb 2010
    Car is no longer available but i tried one of his files thinking its same and it did not work, anyway thanks for your help
    Sent from iPhone 4S
  5. #20
    Dec 2009
    Murano is same as micra c66 done a few
  6. #21
    Dec 2015
    Hi friend my car nissan murano 2002 eeprom s93c66 lost data it show FFFF. I need file, please hell me
    Sent from my C6833 using Tapatalk
  7. #22
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by Ratha View Post
    Mate the board has two 93c66.
    You are reading the wrong one, next time create a new threat with your problem, will be easier to help you
  8. #23
    Dec 2015
    Thx, it has only one chip 93c66 on the board. I try to copy bin file from other and write to the chip. It show meter but the light and fuel level has problem. Where to find oringinal file bin?
  9. #24
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
    Ratha,you still haven't introduced yourself yet,as Neospeedo suggested you do.
    Please do so here : Introduce Yourself
    Thank you...
  10. The Following User Says Thank You to Johnner For This Useful Post:
    jomberykaso (30th December, 2015)
  11. #25
    Aug 2015
    Quote Originally Posted by drpeter View Post
    Are we talking about the same cluster? The dump is not from a Murano I think, on adress 60 I get other mileage.
    Check picture if cluster is the same.
    hello friend, that connection with that programmer is done?
  12. #26
    Dec 2015
    It did not work. Please help
