Results 1 to 15 of 26
    Jun 2009
    Default nissan Murano mileage change
    hi freinds please i have a nissan murano year 2002 with s93C66, i need change mileage from 119751 to 49500km, i join the dump here, please help urgent
  2. The Following User Says Thank You to aeroyas For This Useful Post:
    ftorresg (6th June, 2019)
  3. #2
    your dump not ok,read again
    BR
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by aeroyas View Post
    Your dump s_cks, try to read 16 bit. Post dump 8 and 16 bit.
    Jun 2009
    hello, here is the files 8 and 16 bites, i have download another dump 16bites with 49561 miles but when i put it on the car i get 750000 miles, i put the second file with 16 and i need 49500, thank's a lot
  6. The Following User Says Thank You to aeroyas For This Useful Post:
    drpeter's Avatar
    The Netherlands
    Are we talking about the same cluster? The dump is not from a Murano I think, on adress 60 I get other mileage.
    Check picture if cluster is the same.
  8. #6
    You try swap file and write into eeprom.
  9. #7
    Jun 2009
    hi freind's, prob solved, yes mr drepter it's the same and mileage is in adress 60; i have make many tries and finally work's thank's anyway
  10. #8
    Nee help please for this Murano 2004 , here is attached dump
    need 95,876miles
    Sent from iPhone 4S
  11. #9
    Newbie TIA's Avatar
    Jan 2012
    indonasia
    Default nissan muranoo
    take ur mileage write back
  12. #10
    Newbie TIA's Avatar
    Jan 2012
    indonasia
    Default murano 49500
    tri this file ur file is not ready for correction
  13. #11
    Quote Originally Posted by TIA View Post
    What do you mean its not ready for correction?
    Your file gave me 653xxx.
    Sent from iPhone 4S
  14. #12
    joubliss's Avatar
    Far away
    try this dude.
    good luck.
    *No Help For Leechers
    Press THANKS button if my post was Helpful
    All my Files are Protected with Password
  15. #13
    tried this before, this is turning out to be a nightmare, even retunring th eori file gives no data, just o.oo
    Sent from iPhone 4S
  16. #14
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by sogaro View Post
    Try this, don't have much time, didn't looked at the other dumps, not sure if it will work...
  17. #15
    Quote Originally Posted by drpeter View Post
    Did not work, your file did not even show any value but 0.00 and would not change with drivng. I swapped the dump and got 696043 so the swap is ok but value is wrong. please help further, any value less than 120, 000miles will work not necesarily what i wanted before
    Sent from iPhone 4S
