How do I determine which interlock code to use on any cat flash file. Can I find the info on SiS, if yeah in what section.
Does anyone have good flashfiles for mxs acert to upgrade 550 heavey haul
Try not to use any interlock codes above 100. They usually have the best power. If you use any of the new low nox files they usually have interlocks around or above 300 have seen them as high as 400. Truck will have no power and the driver will be complaining that there is something wrong with the truck have a good one hope this helps
Does anyone have a 3406E 5EK 550 hp 1850 torque file without the high interlock ? Looking for interlock between 0-100 thank you
I hope this is the one you need:
550 HP 1850 PT @ 2100 5EK00001 & UP, 6TS00001 & UP 170-8132 41 DEC98
let me know...
speedy983 (29th December, 2013)
Anybody have flash file 2157402
Goodmorning, Anyone have any success flashing anything higher then the 550 hh into a c15 acert bxs serial? I remember hearing injectors or cam was different in the higher hp motors.thanks in advance..
Pls find the FF # 2157402 and not forget to push the thanks button ------------------------------------------>
jwndriver14 (4th January, 2022), speedy983 (29th December, 2013)
Hello
I need this urgentli, I have e big problem because I'll need chage parameter block with password on ECM from my company,
Please i need de fp kg or help for password
Service Tool Serial Number WB655344-3-T5
Engine Serial Number 8YL42540-PE
ECM Serial Number 01500090KC-S1
Total Tattletale 25
Reason 5
From Interlock 173
To Interlock 234
Diagnostic Clock 9153 hours
hi anyone have 170-8199 or 157-2992 flash file?
Guys I need please the flash file 3099799.
Thank you.
