Page 7 of 101 FirstFirst ... 234567891011121757 ... LastLast
Results 91 to 105 of 1501
  1. #91
    Top Poster SaMirakle's Avatar
    Jan 2011
    Quote Originally Posted by frankiegr View Post
    Do you know if any of these flash files are more than 435 hp? If none of these are more than 435 hp, can I use a different 6TS flash file that has more hp? Like a 475 or 500hp 6TS flash file
    I'm pretty sure they'll all be the same HP but I can double check for you. Also, I'm assuming as long as the engine type and other engine related specs are the same or similar then you should be able to increase the HP.
    ---:..Gratitude is the best attitude..:---
  2. #92
    Quote Originally Posted by SaMirakle View Post
    Thanks SaMirakle - Let me know if you can - I would like more hp, but don't want to change any hard parts
  3. #93
    Jan 2011
    I won't have access to the flash files until Monday so bear with me until then unless someone else beats me to it
  4. #94
    Feb 2011
    hello everyone
  5. #95
    Top Poster gagne's Avatar
    inside truck ecm
    any body have flash files 3484755 tanks all dk
  6. #96
    Top Poster kwtech's Avatar
    Feb 2011
    Canada
    This is the updated version of 348 4755
    Hope this works
  7. #97
    inside truck ecm
    impossible to open message error files RELOAD AGAIN OR WITH WINRAR TANKS
  8. #98
    Feb 2011
    Canada
    here ya go
  9. #99
    Feb 2011
    Canada
    sorry, try this
  10. The Following User Says Thank You to kwtech For This Useful Post:
    speedy983 (29th December, 2013)
  11. #100
    MX
    Default Flash files 1735602, 1517072, 1427139.
    Hi everyone i need flash files for Cat D9R serial: 7TL00912 the files are:
    Thanks.
  12. #101
    inside truck ecm
    do you have new flash files old 3435766 please the 2010 flash thanks
  13. #102
    DK Veteran RSwire's Avatar
    your girlfriends house
    Quote Originally Posted by gagne View Post
    Here is the new flash file.
    Enjoy
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  14. The Following User Says Thank You to RSwire For This Useful Post:
    ATIFRSPS (18th November, 2018)
  15. #103
    Jan 2011
    Default caterpillar flash file
    Hi I'm looking for caterpillar flash file 2707067 if anyone has it I would greatly appreciate it!
    Thanks!
  16. #104
    Quote Originally Posted by dmaan42 View Post
    Thanks!
    Enjoy
  17. The Following User Says Thank You to squirles For This Useful Post:
  18. #105
    inside truck ecm
    hy any body help me for create high interlock password
    ET000596-5-TK
    engine serial =SDP16218-P8
    ecm=26406061QY-V3
    tattletate=47
    reason=128
    from interlock=58
    to =1020
    clock =2 hours
    create pass for me thanks all dk for your help
