Page 2 of 101 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 1501
  1. #16
    Feb 2010
    Please,
    Gentlemen, someone please be kind enough to repost files. And also does anyone have that special prog. that makes factory passwords, other than the 2007 which I already have. What I am looking for is some special prog. that will work with my STW2009B/ET2009C that makes factory passwords.
    Thanks,
  2. #17
    Dec 2009
    Quote Originally Posted by dieselman77 View Post
    HERE ARE THE 2009B FLASH FILE EVERYONE ENJOY
    All Links not work.
  3. #18
    Mar 2010
    Default SORRY EVERYONE HERE ARE THE NEW LINKS
    HERE ARE THE NEW LINKS SORRY ABOUT THAT FORGOT TO PUT NUMBER 9 IN THERE SORRY FOR ANY INCONVENIENCE HAVE A GOOD DAY
  4. #19
    Member servando's Avatar
    Jan 2010
    yo solo tengo q agradecer a todos lo integrantes de este grandioso foro y en especial a los grandes amigos de dk......q sin ellos esto no seria posible -----sin mas por el momento gracias....sorry por mi ingles ....enhorabuena thanks
  5. #20
    Feb 2010
    Caterpillar Engine Flash Files
    I'm working in this truck: GM 1998 Caterpillar 3126 w/ Auto Transm. Engine S/N 7AS43698-NW, with flash file 1894824 (thanks to tonyspamone for this flash file, finally the truck it's working) WITHOUT EPA LoNox Cert.,
    It gives me an interlock of 52 (Personality Module 52) with 190 HP @ 2200 and 520 lb-ft @ 1440.
    I need to add more HP and torque probably 220 to 280 HP and 700 to 850 lb-ft
    It seems (not sure) that I can not use the flash files in these DVDA9021-71 and DVDA9020-71 disks because all have the EPA LoNox Cert.?
    I would like to try this files
    2176762.fls
    2040102.fls
    Please somebody can share them or help me with others flash files witout the EPA LoNoxCert. that can run in this engine?
    Thanks a lot.
  6. #21
    May 2010
    question for you guys, If I have a C13 cat and its a 500hp, can I simply upload a different flash file to it for increased horsepower as long as the engine prefix is the same?
  7. #22
    Feb 2010
    From my recent experience, no, it must match the personality module or interlock. Otherwise the flash file will not work. Check if it's or not low nox too.
    Please help with the old flash files post #26.
  8. #23
    Feb 2010
    Please somebody has old caterpillar flash files disks from around 2001 to 1997 ? without the EPA LoNox Cert.
  9. #24
    Mar 2010
    Hello I need tha flash file 2301407
    thanks!
  10. #25
    Sep 2010
    Hi everyone, great forum. Major props to all of the hard working people who help support newbies like me.
    I have a feeling that this may be a stupid question, but here goes anyway...
    Can someone help me understand what the difference between flash and SIS is?
  11. #26
    DK Veteran RSwire's Avatar
    Jun 2010
    your girlfriends house
    Quote Originally Posted by luckyal View Post
    SIS stands for service information system ie. component testing/replacing, torque specs, repair procedures, and such.
    Flash files are for "flashing" or re calibrating ecm's.
    hope this helps.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
  12. #27
    Apr 2009
    need link flash file 2010...thanks
  13. #28
    Mar 2010
    hi links are dead can somebody reupload please
    thansk
  14. #29
    Sep 2010
    Hi everyone,
    I have CAT SIS.but I don't know how to install it. Is there anyone helping me.
    Thanks,
  15. #30
    Feb 2010
    Please DK members can you help me with this list of cat flash files:
    1630525, 1630524, 1630523, 1630522, 1630520, 1630519, 1630518, 1630517, 1630516, 1630515, 1630514, 1630501, 1630502, 1630503, 1630504, 1630505, 1630506, 1630507, 1630508, 1630509, 1630510, 1630511, 1630512, 1630513. 1630499, 1630498, 1630497, 1630495.
    thanks and best regards
