Results 1 to 13 of 13
    Default VW Golf 2007 PIN code?
    I want to fit a set of 2007 clocks into a VW MK5 Golf.
    I cannot read these clocks using VAG COMMANDER.
    Is there any way I can read/extract the PIN from the cluster so I can successfully adapt them to my car?
    Cheers
    Apr 2010
    With you R250 Programmer....
    Best Regards......
    Thanks for the quick reply!
    Is this the only option I have?
    If so, where can I purchase this R250 Porgrammer tool from, or can someone do this for me on here?
    Cheers.
    Top Poster andresfn18's Avatar
    Feb 2010
    Mexico D.F.
    Default TMT
    YOU CAN USE X-PROG OF TMT COMPANY!!!
    Jan 2010
    Quote Originally Posted by andresfn18 View Post
    which version of commander are you using? i may be able to help
    I only have the v1.4 Commander clone for now
    Can successfully read 2006 clocks, but not the 2007 ones.
    Do you have the full version 7.7 and can you read them?
    Nov 2009
    I use vag prog from smelecom, supertool
    So...
    Does anyone have VAG PROG or otherwise to do this for me ?
    Cheers
    maaxxyy's Avatar
    North Pole
    Have you tried 12233 for login?
    Dec 2009
    Land of Rocks
    Quote Originally Posted by maaxxyy View Post
    Forget it mate.
  11. #11
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Quote Originally Posted by golfather View Post
    Cheers
    For this car PIN can be read using original VAG COMMANDER via OBD or with Xprog-m by soldering some wires.
    Quote Originally Posted by igor6997 View Post
    Best Regards......
    R250 can only change mileage
  12. #12
    umoussa's Avatar
    Jul 2009
    Universe
    That is correct Aminebot
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
  13. #13
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    vag k+can 3.5 is good from raid pin
