opel 1.9 cdti dpf sensor power off with sw?
    Jan 2009
    Default opel 1.9 cdti dpf sensor power off with sw?
    have a sollution?
    Default Egr can be switch off via sw
    Hello you can let your egr programmed out via software our leave the connector loose
    Norway
    You can disable DPF with SPS programing using Tech 2 or MDI but how I can to disable EGR ... that I don't know ... can you please give more informations about that.
    Dear Sir,
    I tried to repflash the ecu software on a Saab 9-3 same Z19DTH engine, but TIS does not allow while the SPS programming to choose a non dpf version.
    In which menu did you found it?
    I also had no success v?with the MDI module...
    Nov 2010
    RS-4
    it is not true, it is not possible to program out the dpf via tech2 for saabs. tis do not allow it...
    England
    yes i'ts thrue... i testet this ... :/
