I have a bin file with an airbag dump how do i use the digimaster to put it on my module, I know how to connect the digimaster to the chip, just not how to upload file to chip
Hi, guys
Can someone edit this digimaster dump file in YHF format to 40000km? Any help on how to do it also would be appreciated.
This car is not on the list, has 93c66 eeprom.
I can't seem to find the way to insert a file here!?
That file needed a conversion from digimasgter *.yhf file to *.bin. I got someone from digimaster convert it for me. They said that conversion software should be in their Keymaster device. Does anyone has that soft?
Anyway here's a bin file.
Dos anyone else find it quite confusing selecting the right model from Digimaster?
When for instance Audi is chosen not all models have years on them and only chip/or dash versions like Uknsi Ver1 C56?
If only odometer chip is given, how do you know what year the procedure is for?
It looks like you have to take the dash apart just to quote and find out if it's applicable to customers car.
That is true!Its a little dificult to know if Digimaster can do that car until you don t have the dash in your hand,and to be very sure always note original odometer value ,and when you read with Digimaster you know when you select the right dash in menu.
I use Digimaster most off time for odometer and its working great
Try this link for update:
China ECU Tools Centre
Ok so you've got your digimaster,
1. What else to get to make your work with it easier?
2. What other device best compliments cars not existing in Digimaster?
3. Can you share with a converter from Digimaster dump format *.yhe *.yhf to bin?
Thanks gentlemen
I would need a converter if I wanted to read an EEPROM with digimaster then edit that dump on the computer with using calculator info. Since it is read in native format it needs to be converted before editing and no changing ending to bin doesn't help here I tried with Winhex.
But no big deal we can use other programmers for that.
I can edit but if data is not what tachosoft calculator or NYO is expecting, editing is not possible.
I had one of these dumps sent to someone in China as suggested by someone, and they converted it for me. They both looked different and the bin one was easily accepted by NYO4.
I use Digi2 without problems,and i put files from unit in others programs too.
I have a dm3 and it does not work on all the cars on list but i think the instructions are faulty
