Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    Germany
    Default Digimaster 2 User Thread does some members have it
    it would be nice to hear from other users how it work and what car they do with the dm2 and to help eachother.
    my cars done
    Golf IV 1999 sdi obd works (VW oBD autoscan)
    Passat TDI ObD Works (VW oBD autoscan)
    Vw T5 TDI 180HP 2004 4Motion OBD dont Work (VW oBD autoscan)
    Mercedes a170cdi 2001 Wiering works no OBD funktion in DM2
    Ford KA 2007 NEC dont work by me
    Merceds w210 2001 works with obd
    Clk Cabrio year 2000 dont work with OBD :-(
    BMW X5 year 2001 on board programming OK
    volvo V 70 2002 OBP OK
    Smart 2006 icp and bsi OK
    93c66 Read write OK from am renault traffic 2007(with help from board "thanks")
    Pajero ICP OK
    Audi A4 RB8 2006 OBD OK
    wbrgds
    Michael
    Member jasonk's Avatar
    Ireland
    I also have digimaster 2
    ive done B5 passats via diag plug
    Mk4 golf via diag plug
    vento via smd board
    200E 1998 merc via diag plug
    so far the only problem ive had is i could not read the chip from a renault maybe i was not making good contact soldering but i had no problem with any other ones
    Germany
    what software versions do you have on your dm2 and on your computer.and do you now what on audi ths a6 and a6l diagnosticscan mean.
    wbrgda
    michael
    jackeldestripador's Avatar
    S.A.
    hello do you know where can i find updates and soft? Can you connected succesfully to pc? i cant.
    hey do you have the installtion disc? my pc dosent recdnise the digimaster to update
    thanks!
    which version u need
    Default this is what show when i turn the dm2 screen
    installtion usb dont work on my pc. i need help pleaseeee
    version-881017-09051201
    is this what you need?
    thank you!
    S.A.
    Quote Originally Posted by kentzee View Post
    Any new version and some "thing" to make work usb...
    DK Veteran marcio1758's Avatar
    Default UPDATE DG2
    CAN UPDATE YOUR DG2 Download the Latest Version 2.82, WARNING DO NOT ATTEMPT TO INSTALL VERSION 2.83 IS A CRACK 'cause that catches their DG2.
    DigiMaster II Professional automotive tools
    Default HELP WITH DIGIMASTER II please!
    hello
    i want to know if i can do with the digimaster ii the e39 bmw x5 2002?
    and how do i do that with the digi? do i need to replace the eeprom? or can i use same one?
    when i connect the wiries it is only let me to go up! not to write lower... what i need to do?
    Default thank you but...
    Quote Originally Posted by marcio1758 View Post
    hey marcio!
    thank you for your help!
    i try this website beffor but steel same results... let me to downloud i go next: showing me like it is installing and i go next: show me :??install??? ??? ??? like that... i finish to install and then it is disapird...and steel the pc dont reconise the digimaster... what can be the problem??
    AvechuchoAxel's Avatar
    Downey, CALIFORNIA
    I have it.... DM2 pays for itself BIG TIME !!!
  13. #13
    Step 1: Uninstall your version of DM2 of your CPU.
    Step 2: Restart your machine, and install version 2.82 with DM2 its connected via USB to your CPU.
    Step 3: Restart your machine again, and start the version 2.82 without connecting your DM2.
    Step 4: Connect your function in DM2 (HOST SERVE).
    Step 5: Connect Asia DM2 your CPU when its version 2.82 from your computer to ask, he must recognize his DM2 without problems.
    OBS. Every time you turn on your DM2 to your CPU must repeat Steps 3-5.
    Link for version 2.82
    http://www.digimaster-ii.com/download.htm
  14. #14
    anyone can tell me how to program a chip that is not on digimaster its for a 95 honda prelude, and how do I program it to adjust the odo without going into odo adjuster on the digimaster? any help will be appreciated thanks.
  15. #15
    Germany
    go to option programmer then to ic and the use your ic thats inside read it post it in dashboard section here and somebody will change it for you the programm it back .
    and that its
    michael
