juozas10
ore other surch the same clear dump for a
SW: 8P0 959 655 C
Bosch 0285001666
Eeprom 95640
or the pass
Thanks a lot
Frank
juozas10
SW: 8P0 959 655 C
Bosch 0285001666
Eeprom 95640
or the pass
Thanks a lot
Frank
Here the bat onee. Can someone clean or vergin it.
95640W
THANK YOU SUPER
Hello
please need to clean the same airbag
Audi A3 Bosch
8P0 959 655C
0285 001 666
eep 95640
I can send the password for this file
or clean my dump?
Thanks Pablo
How do you know that yours file is crashed ?
this unit is second hand
tomorrow insert in car and post dtc from this
airbag unit
Please send me pass.Thanks
A topic that interests me
have you clear dump for 8P0 959 655 C
hey guys, i have the same car+module, what tools do i need to take a dump/erase the crash data?
i have an AGV4000, KKL Interface, Elm327, VCDS and a WillemProgrammer+SPI-Flasher, soldering should be no problem, even schematics for interfaces which could help me are welcome, f.e. vag-commander schematics if it helps me to build up a tool.
EDIT:
we solved the problem with VCDS by just simply deleting the error, the reason why we couldnt delete it earlier was, the the unit was not built in the car (GND) and a fuse + relay was burnt
hi
i have the same problem with this unit . car is audi a3 2007.
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Control Module Part Number: 8P0 959 655 C HW: 8P0 959 655 C
Component and/or Version: Airbag 9.41 H13 4260
Software Coding: 0070612
Work Shop Code: WSC 06314 000 00000
VCID: 428F4E3B664F
00003 - Control Module
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 1
Fault Frequency: 8
Mileage: 89355 km
Time Indication: 0
Date: 2013.05.11
Time: 22:34:04
someone can help me
many thanks
regards
Try and report
pass pm
vampirodauva your pm box is full !!!!
hi
thanks for help
my pm box is not already full.
regards
