Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    portugal-ourem
    Default someone can help me clean airbag audi a3 2007
    brand bosch
    reference: 8p0959655c
    eeprom 95 640
    juozas10's Avatar
    LT
    Quote Originally Posted by doctorelectrical View Post
    brand bosch
    eeprom 95 640
    Hi.
    Try this two dumps...please report...
    Dump not tested.
    Password is in your PM.
    Best regards.
    portugal-ourem
    Default thanks juozas10
    Thank juozas10
    airbag light turned off.
    it's all ok
    portugal-ourem
    Default MY PROBLEM CONTINUES
    MY PROBLEM CONTINUES.
    When you clean the central light extinguished.
    2 days ago but the airbag light turns on again.
    someone can help me
    juozas10's Avatar
    LT
    someone can help me
    Hi.
    What bad code read your diagnostic ????
    Best regards.
    portugal-ourem
    Default module central
    module central
    Above sea-level
    Default 8p0959655c
    Can someone clear the attached file for me?
    Thanks,
    Harry
    Top Poster ionut_mtb's Avatar
    romania
    please write full ecu description!
    Above sea-level
    Default module info
    Audi A3 2005
    8P0959655C
    SW: 8P0 959 655 C
    Bosch 0285001666
    Eeprom 95640
    unhook battery for 30 min to reset computer.
    Clear
    pass pm
    mobileworks's Avatar
    Buenos Aires
    Default Please clear too!!!
    Please clear my dump is audi a3
    Audi N? 8P0 959 655 c unit production 004.08.04
    bosch 0 285 001 666... Thanks Juan
  13. #13
    Above sea-level
    Default control module defective / module replacement
    I have used the file from hacper, but I am now getting the message that the control module is defective!
    Any suggestions? Other 3 faults are under investigation
    I also have 2 other modules (8P0 959 655 L and..H). Can I somehow use these modules if the ..C module is really defective?
    4 Faults Found
    00003 - Control Module
    014 - Defective - MIL ON
    Freeze Frame
    Fault Status: 11101110
    Fault Priority: 1
    Mileage: 108351 km
    Time Indication: 0
    Date: 2008.09.11
    Time: 20:59:31
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    008 - Implausible Signal - MIL ON
    Freeze Frame
    Fault Status: 11101000
    Fault Priority: 2
    Time Indication: 0
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    Freeze Frame
    Fault Priority: 2
    Time Indication: 0
    00590 - Airbag Igniter 2; Passenger Side (N132)
    001 - Upper Limit Exceeded - MIL ON
    Freeze Frame
    Fault Status: 11100001
    Fault Priority: 1
    Time Indication: 0
  14. #14
    Land of the Sun
    Quote Originally Posted by juozas10 View Post
    Hi.
    Dump not tested.
    Best regards.
    Hi Juozas
    I need to clean the same airbag doctorelectrical
    I can send the password for this file or clean this?
    Audi A3 2007
    8P0959655C
    0285001666
  15. #15
    Land of the Sun
    It works Solved
