Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
  1. #31
    can you place dump on immo one and in anew?
  2. #32
    Hungary
    Default pin?
    Hy all! I need a pin for octavia 2 with simos ecu.
    here is the dumps from ecu (93c86). 8 or 16 bit
    THX
  3. #33
    M93C86W-x8-Orig.zip = 45527
    M93C86W-x16-Orig.zip = 55217
    look this
  4. #34
    umoussa's Avatar
    Universe
    Quote Originally Posted by lordcroft View Post
    THX
    Rar you files please
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
  5. #35
    Member ngv1515's Avatar
    NOVA USA
    Quote Originally Posted by giuliani77 View Post
    No blink but the owner don't care (need his car and also is a solution for this).
    can you take the bulb out?
    Do a good job the first time or dont do it at all!!!!
  6. #36
    Russia, South Ural
    THX
    login in PM.
  7. #37
    Nov 2010
    Hi , can sameone help with immo off
    skoda fabia 047906033j
    Simos 3PB SJ035
    Thanks in advance
  8. #38
    dadal's Avatar
    Aug 2015
    car:
    skoda 1.4
    ecu:
    047 906 033 E,
    SIEMENS 5WP44202 10
    Benzin Simos 3PA
    need immo off, I have an important question, need I to read/write as 8 or 16 bits (93c76) ??
  9. #39
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by dadal View Post
    car:
    skoda 1.4
    ecu:
    047 906 033 E,
    SIEMENS 5WP44202 10
    Benzin Simos 3PA
    Here friend u are
    Cheers
    Press "THANKS" button. just one click, CHEERS
  10. The Following User Says Thank You to electrones For This Useful Post:
    dadal (26th July, 2017)
  11. #40
    dadal's Avatar
    Aug 2015
    Thank you Electrones,
    Thanks + Rep are added for you
    siemens simos ECU"s must be always read/write as 16 bits ??
  12. #41
    Aug 2019
    Hello All,
    I have a Skoda Fabia 1.4 MPI with 047906033C Siemens ECU. I think when I made a throttle valve adaptation after cleaning, the damn Chinese VAG-COM 409.1 adapter cable caused some problem in the ECU SW.
    Now the car stalls, there is a lumpy idle and when accelerating the engine is jerking and have error codes appearing.
    I bought a used ECU, but I'm not able to read out the EEPROM content nor of the original, nor of the spare ECU.
    I was able to read out the PIN code of the instrument cluster (which is the same PIN as the original ECU) with VAG K+CAN Commander.
    Please give me a hand and give some advice what HW and SW needed to download the EEPROM content of the spare ECU.
    Or how can I re-program/reset the original ECU?
    I have:
    - VCDS HEX V2 18.9.0
    - VAG K+CAN Commander 3.6
    - VAG-COM 409.1
    Thanks!
  13. #42
    kiszka's Avatar
    Quote Originally Posted by banalac View Post
    Hello All,
    I have:
    - VAG-COM 409.1
    Thanks!
    perform the adaptation correctly and the problem will disappear
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  14. #43
    Aug 2019
    I done adaptation several times since the failure with a VCDS 18.9 HEX V2 cable.
    Problem is still exist, so adaptation does not help.
    I think something is messed up in the ECU flash or EEPROM.
  15. #44
    kiszka's Avatar
    the cable is 100% ok
    the problem is the software, this engine does not do it correctly
    Reality of life :
    3:Everyone lies
  16. The Following User Says Thank You to kiszka For This Useful Post:
    banalac (12th August, 2019)
  17. #45
    Aug 2019
    Ok, thanks for the clarification. Do you know what kind of SW, method/procedure should I follow to get the things right?
