for upgrade to 3.1
http://www.noregon.com/allisondoc/aedupdate.html
for upgrade to 3.1
Thanks for a great site.
hello guys,
what interface can we use for allison?
thank you
Best interface to use would be the "Nexiq USB-Link"
Hey rp1210a, what OS is needed for allison doc 8? tried ver 7 but it tells me wrong OS or OS version. I have XP sp3, any help would be great.
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
Version 8 should run on XP, Vista and Win7. Havent tried it with 64 bit Win7 though. Try right clicking on stup.exe and then run as administrator. If that doesnt work run as current user but uncheck protect my computer. At what point in the install are you getting the error message? Do you have a modified version of XP or just basic XP sp3?
I haven't downloaded ver 8.0 yet, if it didn't work on my system. I have basic Xp sp3. It gives me the error when I double click on the install msi.exe or the msiw.exe but not the install.exe. after install.exe, win installer ativates gathers info and than nothing. sorry just checked I have xp sp2.
you might as well try ver8 and see if you get same error. Run it using setup.exe not the msi file. I know for fact it will not install using the msi file.
Ver. 8 working well on my machine now. Thanks rp1210a
Rock on Greekie
Hey guys can someone help me. I'm having trouble connecting to a bus, did it 2 months ago with ver 5.2,went to hookup today wih ver 8.3 and no connection. Tried smart connect, tried every product listed, j1708/j1939. I'm using an IC4 interface spent 2 hrs trying to connect to it and a few others, no luck. Any ideas I'm at a loss. Help please
Got it going, had to uninstall and reinstall IC4 drivers. Works good now.
hello there i need a password generated for 8.3 key 1001585878.
would be be great, thanks
also on a side note, I installed the program, go to install the up date, and I get an error message saying allison DOC is not installed properly? and ideas.
rp1210a/ greekies Thanks fellows you are the Shiznitz. Woot Woot ShareOn....!
Thanks again
somebody have the installer for Allison DOC? For Fleets (1000/2000) Installer and the Allison DOC? For Fleets (3000/4000)?
