    florinyes's Avatar
    London Middlesex
    Default Mercedes C200 not firing cilinder 2 and 3..
    Hello guys
    next door garage call me to see this one..i know common on this but anyone got a fix for this ecu's? Bosh 0261200614
    Willing to buy you the beers if fix available.
    Cheers
    Whatever seems impossible is just not yet important enough.
    Sometimes it is easy to repair:
    f car is 4 cilinders has inside ecu 2 transistors if car has 6 cilinders, ecu has inside 3 transistor. Locate wich transistor is defective and change it, sometimes I change some components around when transistor has burned.
    I must say is common problem in VDO ecus in mercedes, but have not repaired yet a Bosch one with this problem.
    For locate with transistor is, only must Know pinout of ecu and a simple multimeter will do the rest.
    Fec001's Avatar
    I have the same problem with same ECU. Any info about opening ECU easier?
    What is the "name" of this ECU? MEx.x??? or?
    workshop
    PMS,no easy open
    Aug 2019
    Germany Hessen
    Top Poster abdulsattar's Avatar
    Nov 2016
    Hi mate, let me give you my 2 cents:
    this ecu is bulletproof and rarely defective. its either the ignition coil itself, firing 2+3 or its the wiring harness.
    check the entire wiring harness from ecu over intake manifold/injectors to ignition coils for rotten cable insulations.
    youll find your problem right there
